3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Building a Medieval Gauntlet
Step 3Making your plates Safe (Optional, not really though)
If you've been using tin snips like I did, You've probably been left with some fairly dangerous edges on some of your finger plates. They can easily scratch things, and people, but they are also be able to cut, similar to paper cuts.
****UPDATE*****
A lot of people have been telling me to just file them down with a hand file. I fully sanction this course of action if you have the skills and a file. I did not do this in my case because I was building them inside of an apartment and I didn't want to worry about metal dust going into the carpet / air. I don't know if this is a realistic concern or not. But I suggest wearing a ventilator mask if you're doing any power sanding.
The way I made them safe was to coat the edges with a latex based verathane. I got a tiny can @ a paint store for $10, and I barely used any of it, a 50 ml bottle should be more than enough for your entire glove.
A cheaper solution is white glue, but I find that it doesn't work as well.
Dip your brush in your verathane, and then wipe most of it off so that you don't have any big globs on your brush, and then run your brush along the edge of your plate so that your brush and the plate make a ' T '. Most snips leave a slightly serrated edge, the verathane will quickly fill all the little bumps. Wait for it to dry and then add another coat. Keep coating it until the edges are no longer sharp.
It'll usually take no more than 3 coats to form a thick enough layer to make the edge safe.
7 comments
Dec 8, 2010. 12:31 PMcountspicy says:
when i made mine i left extra material on the sides and folded the metal over itself to get rid of the sharp edges.
Jul 10, 2009. 9:14 AMNimue32 says:
Actually, you might want to try a burnisher. It's an implement used in jewelry makes. I find that running the "blade" along the edges takes care of all the burrs and sharp endges when I work with metal. (I'm making an armor ring right now, which is why i'm here right now!)
Mar 3, 2009. 6:37 PMUnit042 says:
Ummm... hand operated metal file, anyone?
Apr 2, 2009. 12:06 AMCuicydepunk says:
That's what the file would be on your handy swiss army knife or nail clippers... I'm not sure if you were pointing out that you could use one or if you were asking what one was.
Apr 5, 2009. 10:57 AMUnit042 says:
I was just pointing out that covering up the sharp edges does not solve the problem, and that a safer method would be to outright file the edge down. Kinda like the parable about sweeping the dirt under the rug... ... ... Gotcha! There is no parable about it, it's a cliche.
Apr 5, 2009. 5:53 PMCuicydepunk says:
Yes agreed. If this was my project I would use a rough sand paper, and slowly work my way down to a finer grade until the edges were actually rounded instead of coverred or filed.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
31
Author:Deathcapt
I make costumes for fun! Even though my username is deathcapt, I'm not a wierdo or anything,it's just something that stuck.
