loading
Step 14: Making the Thwarts
To make sure that the boat keeps its shape you need to install to thwarts a little less than 1/3 of the distance from each end.
I measured along each side 32 inches from the stem and stern and made a tick mark (The tick mark is vissible in the first picture of step #15). Then measure across the boat at those points. Mine was about 24 inches. I then layed the thwart acorss the Beam (Top) so that  they over hang just slightlyand traced the curve, at both ends of the thwart. Cut this on the Band saw. Next turn the thwart on its edge and mark a line that goes right down the center as  in the second picture below (I made the line very dark so that it would show up in the picture). Being very careful resaw the stock on the Band saw, It will end up being about 5/8ths of an inch thick. It is much easier to sand this before you install them.
<p>I made it! Thanks for the 'ible!</p><p>Was a really fun project. I learned a lot on this and will do a couple things differently on the next one. As always when learning something completely new.</p><p>It took about 1.5 weeks to get it to the finished state but most of that was the epoxy and painting. Had to wait for dry weather which is fairly rare in Ireland.</p><p>Unfortunately it is highly unstable. I think partly because I am fairly scrawny so I don't displace enough water. I think for the next one I will try to stay true to the intent of your 'ible, and keep it one sheet, but will try to incorporate some design details to stabilize it: <a href="http://www.canoeing.com/canoes/choosing/design.htm" rel="nofollow">http://www.canoeing.com/canoes/choosing/design.htm...</a></p><p>Also I will try to use marine ply and only seal the joins as I really don't like working with solvent based materials.</p><p>Thanks again! This has me motivated!</p>
<p>Great Job!. I don't know if you saw the other one I designed and built. It is more of a pram design and is a whole lot more stable. It also uses just one sheet of ply. Good luck with yours and I hope you have a lot of fun using it.</p>
Thanks for the quick response! Did not expect it. <br><br>I did see your other design and I am sure that it is way more stable. <br><br>I am more interested in the aesthetics of a canoe though so will give another wack at that. <br><br><br>
I made it, just like the instructable said. My very first build (except the saw horses its sitting on) except i dont have a table saw so i had to use my circular saw for almost everything. I used a jig saw to cut out the bottom and after i attached it, i went back around it with an oscillating tool with a wood blade... and i used the oscilating sander in lieu of the belt sander... but a belt sander wouldve been so much better...
<p>Looks great, what did you stain it with? Did you use an adhesive for the joints?</p>
me and a couple of friends built this boat from your instructable, we found them to be a little too rocky so we have bolted two together to make a small catamaran and they are brill, i use a small 3.5hp out board on mine, you can stand up in them now, only one draw back is that you can not paddle them on your own. <br>i will try and get a pic for you to see, we also use them on a small tidal river and use a plank to make a seat to sit higher above the water line.
I would love to see a picture of it. Did yiou see the other one I designed? It has a square bow and transom. This gives you more stability as the boat is wider at the ends. <br>Good luck with yours and stay safe.
The boat looks great! I am going to build one. How stable is the flat bottom?
It is pretty stable, You are seated on the bottom and I have swamped it but I had to lean a lot to do it. <br>I weigh about 200 lbs and had about 5-6 inches of freeboard. <br>Good luck and psot a picture when you are done please.
How many people could fit in this boat?
It is strictly a one person boat. I weigh about 200 lbs and it has about 6inches of freeboard (you can see that in the pictures where I test it out at the quarry). <br>I suppose you caould put two small children in, But I don't reccomend that. I also strongly suggest wearing a life preserver/ jacket of some type.
Thank you. The other thing I was wondering is how balanced is it?
Couple of things, you are sitting on the bottom but it is a very narrow bottom. It does tip but you need to make a conscience effort to do it. <br>I pulled the paddle very hard and it didn't tip in eiother the quarry or the pool.
Ok thanks :D
Verga, I have been considering prices for plywood... Yes I am going to build a boat. I always do a lot of research before I build something, though. Researching latex and fiberglass now...
nice job well executed for sure 5/5. This boat is ideal for calm waters like lakes. Do you have any recommendation for sea waters? Any change to shape? any idea?
you wouldn't want a small boat like this on the ocean. If you did, it would have to have cover from water getting in like a kayak, and I recommend filling it with Styrofoam so it can float.
and maybe a V shape at bottom....
Hull shape is always important. Go on the ocean with a small boat, and see how treacherous it is, and figure out what you need to do.
I love it! I just sold my 2 sheet kayak/canoe last week and was thinking a of building something to replace it. This might be the ticket. Quick and easy. <br> <br>
That's like a lake! Beautiful! :D
Roughly the same, You will have to do some planing with a hand plane or belt sander to get the angle. <br>Good luck with your build and feel free to ask any other questions
So basically, if I don't have a table saw, I can just buy 1x2s and it'll be the same?
Truly and awesome build! I'm seriously considering making one. Thanks alot for the instruction!
Quick tip for you....if you cut all of your plywood parts on a sheet of 2 inch board insulation, your work surface doesn't have to suffer. Trust me..I learned this on the hard way!
Good tip. <br>I just layed mine on 2 2x4'sand set the circular saw depth for 1/2 inch. <br>But your method will give it more stability.
about how much did this cost and how much weight can it hold?
Cost is based on the quality of the matierials you buy and how many mistakes you have. It also depends on what you have laying around the house. Also the rules for the competition I was in did not allow me to use any glue for this. Some glues are quite expensive, or if you coat it with an epoxy or Polyester resin that will add to the cost. <br>That being said The 1/ 4 inch B/ C plywood I used was about $20-$23 <br>The 2 x 4's cost about $5 each(I bought Premium grade to reduce the knots and I spent about 40 minutes going through the pile. <br>I used coarse thread drywall screws these were about $5. I had to use 1&quot; but 3'/4 would have been preferred. <br>Primer is about $8- $10 and Paint is $10- $15. <br>All told about $50. <br>As far as weight I weigh about 200 lbs witht he paddle life vest about 210 lbs and I had about 4-5&quot; of freeboard.
Very nice job Verga! I have a question I hope you can answer and forgive me if the terminology is not correct. Could I square off the back of the boat - make about a one foot wide transom and use an electric motor with this design? I'm sorry if this has been asked already, but I couldn't find it... thank you!!!
You might be able to, if you go tot he &quot;One sheet wonders&quot; yahoo forum they have several designs with a squared back. This boat is very tippy and with me in it. there is only about 6&quot; of freeboard on the side. I weigh about 200lbs
Thanks Verga... you confirmed my fears (I'm about 215) so I may have to go to a &quot;two sheet wonder&quot;... all the best my friend, Nick
Hi, I did exactly that with this design with the thought of adding a small electric outboard on the back. I already had it from on old canoe.. <br> <br>I also squared and changed the angle on the bow, put a keel strip, made it a bit wider and lowered the thwarts so my kids could sit on them .. <br> <br>Sadly It was dangerously &quot;tippy&quot; and we didnt even try the outboard. <br>In the end we just added some rollocks and have been happily and safely rowing on our local river ever since. Here's a pic of my son....Cheers
Thanks for the feedback. It looks like you did exactly what I thought about doing - sounds like you saved me a lot of unnecessary work. Thanks again and the boat (and your son) look great!!! ATB, Nick
WOW very nice job and he looks like he is having a blast!
Beautiful and simple. Great 'ible. 5/5<br> <br> A keel strip about an inch thick by 3 inches wide, would help a lot with tracking. It would also help with the strength of the bottom.<br> <br> I might adapt your design to an outrigger sail boat for my kids to play with. I will however use caulking and a little stronger gunal bands. I don't have to follow your race rules. :-)&nbsp;
I took first place in my age group and first place over all. I will a couple of additonal pictures
Hello Vegra, could you please be so kind and let me know the &quot;metric&quot; sizes for the &quot;step 1 materials&quot; And please explain what &quot;B/C grade plywood&quot; is Thanks you
This is the standard American grading system for &quot;select&quot; softwood lumber (US Dept of Commerce ratings / standards). B/C is lumber that falls into one or the other of these two definitions (same system is used in Canada as a lot of softwood is exported to the US) B: &quot;A few, small defects but nearly perfect. Used for fine furniture, exposed cabinetry, trim, flooring.&quot; C: &quot;Small tight knots. May be nearly perfect on one side. Used for most furniture, shelving, some trim and flooring.&quot;
Thanks. two questions are still there:<br> <strong> (1)</strong> 2 pieces 8&quot; =&gt; (foot?)<strong><br> (2)</strong> 2x4's =&gt; (2 inch x 4 inch?)<br> <br> No need for the metric sizes any more, i can convert them for myself<br> <br> Mfg Lars<br>
Yes the 2x4's are 2 inches (Actual size about 1 3/4 inch) and 4 inches (Actual size about 3 3/4 inch) by 8 ft long.
Good idea Good work
Nice job - both boat and instructable. Did you use exterior / treated ply ?
I used exterior 1/4 inch A/C, it was not treated. I was worried that it would need longer to dry than I had to build it.
I live in Penticton BC Canada and we had races every year the rules were the boat had to be made out of cardboard only and duck tape only and paint the boats were very creative and lasted for as long as two hours
This is Great!!! Did you win the competition?
seeing this step makes we wonder did you consider a mouseboat? there is also a yahoo group for them, I have made 3 of them so far. there are no posts in them just chine logs, though making enough chine logs from the one board could be a challenge. Just wondering and also if any one is being bit by the boat bug starting with a mouseboat is even easier, though you won't end up with such a &quot;boaty&quot; look when done as a mouse is a box. great &quot;Ible&quot; and a great build log for the onesheetwonders, I got the email about this one.
I did consider the mouse boats, but I know that the canoe design is faster than a blunted bow, and this is a race. I also have a lot more experience building this type of boat. I do like the pram design and might consider something like that for next year if this one is not stable enough for the race.
About This Instructable
140,828views
474favorites
License:
More by Verga:Herb/ Flower Garden Rotating Bin Composter Tub Garden
Add instructable to:
