3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Building a POV, Propeller Clock motor
Meanwhile the Propeller Clock of Bob Blick is known quiet well in the DIY communities http://www.bobblick.com/techref/projects/propclock/propclock.html .
Some people do crazy things http://www.ledcontrol.narod.ru/eng/index.htm .
One problem building such a clock is to find a motor. The motor has to be silent, it has to make more than 25 turns per second and the power for the clock circuit has to be transfered somehow to the pov pcb that is mounted on the turning spindle of the motor.
Bob used a motor from an old floppy disk drive in his project. He modified the motor to use an extra coil as a generator for powering of the circuit. The motor that bob used was a non regulated one from a very old floppy disc drive. These are hard to find nowadays and the speed is not very stable.
Daryl bender http://www3.sympatico.ca/surfin.dude/creative/clocks/propclk/blick.html also modified a motor. Other people transferred the power using brushes. Brushes make noise, give bad contact and are ugly ...
One can also mount a battery onto the moving part http://www.atomicfireballs.com/pivot/entry.php?id=53#body , but this battery need to be replaced now and then.
Phillip used a fan as a motor and build his own generator http://www.activevb.de/rubriken/kolumne/kol_27/propclock.html .
Here are many links to different solutions http://www.luberth.com/analog.htm and pictures of clocks that use brushes to transfer the power to the pcb.
I decided to solve most of the problems by using motors of old 5 1/4 inches floppy disc drives. These motors are brushless dc motors that are very silent while running. They are cheap. The build rather big mounting platforms. The speed of the motors is rather constant because it is regulated. The motors should be found rather easy in surplus stores for a small amount of money.
Step 1What you need
What you need
Material
- two motors with working circuit boards
- one voltage regulator 7805
- one variable resistor (values depend on the circuit board. mine was 50k Ohms)
- one capacitor (value depends on the circuit board, mine was 10nF)
- glue, best use is epoxy based
- some material to fill "space! (I used broken experimental pcb boards)
Tools
- a soldering iron
- pliers
- solder
- screwdriver
- dremel tool
- ... the standard stuff ... ;-)
37 comments
Aug 13, 2011. 7:47 PMdumfart says:
Hmm, anybody tried this using cdrom drive motors?
May 26, 2010. 9:13 AMswimray5 says:
Hey, I know this may be a stupid question, but what are you grounding to here?
May 27, 2010. 9:31 AMswimray5 says:
Ok, so let me get this straight, in the physical system there is no "ground" ? I'm just wondering what the actual wire connects to. After powering the LED, the negative end goes where?
Jan 10, 2011. 2:52 AMls00181 says:
it connects just before the capacitor (ie to the common end of the coils)
May 12, 2009. 3:05 AMThe ed says:
must the motor have specific rpm or something like that? Can I just buy a motor from any electronic shop?
Feb 9, 2010. 11:29 AMAlgag says:
he said it must make at least 25 turns per second so you would need
25*60= minimum RPMs or 1500 RPM
Feb 12, 2010. 5:15 AMThe ed says:
ok, thanks. So can I just buy a motor with 1500RPM and make it the motor to turn the clock?
Feb 16, 2010. 6:52 AMAlgag says:
 yes that should be fine
Mar 4, 2010. 5:58 AMThe ed says:
Great, thanks a lot
Mar 9, 2010. 4:06 PMAlgag says:
 anytime
Mar 26, 2009. 7:04 PMaqil says:
gurandil2..
Feb 22, 2009. 9:19 AMemdarcher says:
that looks like the inside of the motor I took out of a cd-rom drive that I cant get to work. how do you get those motors to work?
Jan 21, 2008. 11:33 AMkillerjackalope says:
Just had an idea of how to power a generator from the motor, has a mounted cog spinning around a toothed ring, the cog spin the motor, does that make sense?
Jan 22, 2008. 7:23 PMkillerjackalope says:
There's an overhead view, hope that helps explain...
Jul 5, 2008. 1:34 PMgizmohigh69 says:
OK I have a question aim a lazy person but I love electricity and my license is suspended and I can't drive so aim trying to figure out a way to hook up my bike to a motor and run off the motor but the thing I want to do is charge it using a magnetic coil when I petal the bike that spins the coil and charges it so what I need to figure out is how to make a coil that will spin and charge and make enough power to pull me and the bike and I can add capacitors to it but I don't really have a good idea maybe you can help
Jan 23, 2008. 8:36 AMkillerjackalope says:
just an idea becasue people seem very reluctant to try and generate the power through fields... The main problem with this is noise however four small motors on counterbalancing eachother would just about make the power requirements.
Jun 1, 2008. 11:16 AMDerin says:
i found 7805 in an ups woot
Apr 26, 2008. 7:36 PMmcdonn123 says:
I've got one just like that, only smaller. And I can't wire it very easily because it connects to one of those flexible copper colored things.
Apr 2, 2008. 5:46 PMheavy.metal.nguyen says:
I've always wondered what those do. I found two of them in a VCR and I just like the look of them.
Mar 30, 2008. 1:31 AMTheMadScientist says:
hell yeah, FINALLY a use for those damn old disk motors... they Looked useful, but I just hadn't found a use for em yet...
Mar 10, 2008. 9:46 PMcodydean says:
im 13 and ive been doin stuff like that
Jan 3, 2008. 5:00 AMReKa says:
Happy New Year! Looking on an old 3,5 inch disk drive I saw a little magnet and a sensor which are doing revolution detection there. Perhaps its a usable hint for you?
Dec 22, 2007. 5:27 PMHeliosphan says:
That is ingenious! I myself tried building a POV device using a PIC chip and a long line of LEDs, but I used an onboard battery. As you can expect, the results weren't to my satisfaction. So I hit a brick wall because all the solutions I've seen, as you say, involve xferring power thru contacts in or around the motor. This solution is a great way of doing it, I'd imagine its quite efficient too, you end up losing a bit of efficiency by having to haul the generator round and round but it is truly a wireless power source - Electric fields do it instead! I'm amazed, thanks a lot for this but hacking motors is a bit out of my league really and I'd imagine out of a lot of peoples league. On a side note, how do you implement full revolution detection for the microcontroller? I'd imagine a hall effect sensor? I actually tried using a bike computer sensor myself. It worked well but the sensor housing was too big for my design. A hall effect sensor is surprisingly elusive here in Blighty so I packed the whole project in - too dejected with all the failures. Thanks, a great instructable - difficult to describe thoroughly.
Dec 22, 2007. 7:25 AMburningsuntech says:
Nothing like a simple answer to a complex problem. Nice job! I'm building one. Keep up the good work.
Dec 17, 2007. 9:37 PMDa_Fudge says:
cool! I want one!
Dec 18, 2007. 11:57 AMalfonso says:
That will be awesome with the POV clock!
Dec 17, 2007. 6:37 PMT3h_Muffinator says:
Sweet! I can't wait for the POV/clock on it either!
Dec 17, 2007. 4:19 PMBongmaster says:
looks good so far :)
Dec 17, 2007. 3:26 PMzachninme says:
Thats awesome! Can't wait to see the POV on it!
Dec 17, 2007. 3:01 PMGorillazMiko says:
i agree with lebowski, nice job!
Dec 17, 2007. 2:52 PMlebowski says:
Nice job!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
24
Author:frickelkram
radio amateur since i was 16, education in electronics, built extension-cards for ibm pc, build machines to make concrete, studied communications engineering, had a dot-com company in the late ninetie...
more »
