3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Building a POV, Propeller Clock motor
Step 2Working principle
Working principle
The idea is to use one of the motors to make the pov circuit spin around and the parts of the other motor to work as a generator for electricity.
The driving motor part is basically untouched. The speed of a floppy disc drive is to slow. Therefore the motor driver need to be modified to make the motor turn faster.
Parts of the other motor can be used to build a generator. Using a dc brushless motor we get three phase current, see http://en.wikipedia.org/wiki/Three-phase_electric_power . The three phases are rectified with three diodes and the resulting voltage can be used to power the pov circuit.
The coils of the generator need to spin with the pov pcb. Therefore the magnets need to be mounted onto the static pcb of the motor and the star with the coils onto the spindle of the motor.
4 comments
May 26, 2010. 9:13 AMswimray5 says:
Hey, I know this may be a stupid question, but what are you grounding to here?
May 27, 2010. 9:31 AMswimray5 says:
Ok, so let me get this straight, in the physical system there is no "ground" ? I'm just wondering what the actual wire connects to. After powering the LED, the negative end goes where?
Jan 10, 2011. 2:52 AMls00181 says:
it connects just before the capacitor (ie to the common end of the coils)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
24
Author:frickelkram
radio amateur since i was 16, education in electronics, built extension-cards for ibm pc, build machines to make concrete, studied communications engineering, had a dot-com company in the late ninetie...
more »
