Step 10Making the Eye
Taking the time to make sure it came out as good as possible was very important. After finding a suitable plastic lens I could start on making all of the other necessary pieces. Here is an image of everything that makes up a finished eye. The black disks were designed and laser cut to create the groove pattern you see in the final eye. The translucent disk will help diffuse the red LEDs, and the black rod will create the dot in the center.
After roughly fitting all the pieces together I noticed that the light spill coming down the sides of the lens was really messing with the overall look of the eye. I resolved this issue by coating the inside of the lens with black electrical tape to prevent any light leak from happening. This way the only light you will see is coming through the translucent surface of the eye. The final result is perfect.
All that's left is to install the eye and connect up the power. With the electronics finished and installed, all that remains is the detail work.
Materials used for this stage
Skil Router bit cover from Lowes
2" protoboard
4 bright red LEDs
Custom Laser cut and engraved eye detail pieces from ponoko
translucent plastic sheet
Small piece of black plastic rob
Laser Cutting done by Ponoko.com
-halosk8ingking
One quick question regarding the eye. Are your two designs saved anywhere on Ponoko's website?
(Thank you for your link & your availability, by the way)
Really impressed by your whole work o_o
What kind of glass/plastic'(?) did you use (the one you beveled with router bits) ?
Thanks for you reply ;)
Link
