3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Building a Priority Board
I made what I call a "Priority Board". I'm a big fan of to-do lists to capture tasks so I don't forget. But the only problem is that you can't reorder them without rewriting the whole list.
Whiteboards are nice, but suffer the same problem. I could use index cards or similar, but then I would be wasting materials every time I finish a task. I decided what I needed was something I could shift around easily, but that didn't use any consumables.
The Priority Board was born. Each piece is made from whiteboard material, with magnetic backing so it can stick to a magnetic surface (a filing cabinet in my case).
It's easy to reorganize the list at a moments notice when your priorities suddenly change:
Step 1Materials and Assembly
I bought magnetic tape and a cheap whiteboard. Note: It's important not to get a magnetic whiteboard. I bought one of these first, and since they're only very thin metal sheet, when I tried to cut it the edges were way too sharp. (I actually cut my thumb knuckle quite badly.) The non-magnetic ones are much better for this application, since we need pieces that can be moved over and over again.
Although scissors would probably have worked, for speed I used a bandsaw to cut the pieces out. I chose 3cm high and 15cm wide for each piece.
Apply the tape to the pieces. Only a small amount of magnetic sticker is needed for the back.
The tape is still quite curved after being rolled up for so long, so I weighed all the finished pieces down with a book for a while to help the adhesive stick.
5 comments
Sep 15, 2009. 3:22 AMporcupinemamma says:
"antidote" a remedy to counteract the effects of poison. (Really... you should trust my cooking! Wanna come over for dinner?Lol)
Aug 8, 2009. 9:50 AMguyfrom7up says:
lol, love the antidote
Jul 13, 2009. 7:07 PMRaisedByRobots says:
good idea!
Jul 13, 2009. 1:59 PMlemonie says:
I believe that air-traffic control backups work in a similar way... L
Jul 13, 2009. 1:00 PMWard_Nox says:
occurs to me you can use this to make your own Colbert On Notice board
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:mechatronics
