Introduction: Building a Simple Computer
Step 1: Layout of Basic Computer Components
Building a personal computer all comes down to personal preference; hence why it is called a personal computer in the first place right? Instead of using this instructable to analyze what kind of specifications each person needs to run a computer for themselves, It’s built around as more of a guideline to point you towards a direction for building your own personal computer; and exactly what key parts you need to do so with. Now with every computer, you need some key parts;
· A Computer Case
· Power Supply
· Memory
· Hard Drive
· Motherboard
· Processor with Heatsink (so the chip won’t overheat.)
· A Graphics card (On-board or a separate card)
· DVD/CD-ROM Drive
· Operating system software (in this case Microsoft’s Windows 7 32-bit Software)
Keeping in mind in this computer build will be running Windows 7, the parts used here are more than sufficient to run the operating system. Windows 7 requires;
· One Gigahertz (GHz) Processor
· One Gigabyte (GB) Ram (32-bit software) or two GB RAM (64-bit software)
· 16 GB available hard drive space for 32-bit software or 20 GB for 64-bit software
· DirectX 9 Graphics device with WDDM 1.0 Higher driver.
Now before going on with each additional step and watching the video tutorials, I have included diagrams of each individual part being used in this particular build. Doing this will give you a little more insight on what is going on in the videos and hopefully give you a little more understanding on how everything on a computer works together. The Video’s are broken down into steps, and I have included what parts each step will require to complete the tasks.
Step 2: Video Instructions Parts 1 Through 4
Parts and Tools for each Step
(Note: all screws came with the case and Motherboard)
A. Part One; The Motherboard
i. Tools needed
- Phillips Screwdriver
ii. Parts needed
- The Case, 6x Grounding Screws, 6x Motherboard Screws, Motherboard with Panel.
B. Part Two; Processor and Heatsink
i. Tools needed
- Flathead Screwdriver
ii. Parts needed
- Processor, Thermal paste (located on the heatsink in this case) and the Heatsink.
C. Part Three; Memory and Graphics Card.
i. Tools needed
ii. Parts needed
- 1x Board Screw, 4x DIMM System Memory, Graphics card
D. Part Four; Case to Board
i. Tools needed
- None
ii. Parts needed
- Connectors from the case
Step 3: Video Instructions Parts 5 Through 9
A. Part Five; Installing Bay Components
i. Tools needed
ii. Parts needed
- DVD/CD-ROM Drive, Hard Drive, Hard drive Bay Connector, Power Supply, 4X Board Screws.
B. Part Six; Power Hookup
i. Tools needed
- None
ii. Parts needed
- From the power supply; 24-Pin ATX power connector, 8-Pin Processor connector, PCI-E 4-Pin connector, Molex connector for DVD/CD-ROM Drive, SATA power connector for Hard drive
C. Part Seven; Connecting drives
i. Tools needed
- None
ii. Parts needed
- SATA Cord, IDE Cord
D. Part Eight; Finishing Build
i. Tools needed
- None
ii. Parts needed
- Molex connectors from power supply to case fans.
E. Part Nine, Windows Installation
i. Tools needed
- None
ii. Parts needed
- Power cord, Monitor with DVI Cable, PS/2 Keyboard, USB Mouse, Windows 7 Home Premium Operating System Software.
