Building a Small Cable Suspension Bridge - the Basics Plus a Video Demo
Introduction: Building a Small Cable Suspension Bridge - the Basics Plus a Video Demo
Outside Contest 2017
Second Prize in the
We built this bridge and wrote a “how we did it” book about the process a few years ago. I thought it would be fun to share the basics of this design as an Instructable for people who have enough skill to be able to take the information and work with it. And as we do in our book, we recommend having your specific design approved by an engineer just to be on the safe side.
So here you go! We also have a blog with a fairly recent materials price list, hints and tips, and other projects. Link is at the end of this Instructable.
PS Thank you all so much for the votes in the Outdoors Contest! We are a finalist as of October 6, 2017, and are delighted!
Step 1: The Design
Here is our design for an 80’ long walking bridge that spans our creek and is set back far enough for a serious flood. The challenge was to do as much as possible without the need of machinery or swimming. Even if your creek isn’t that wide, consider flood stage and go from there.
The drawing shows everything used to build the bridge other than the cable locking system, which is pictured below and in the video.
Step 2: Install Four Posts
After clearing a site, we installed four posts.
Step 3: The Dead Men...
Dead men are a vital part of this design (the foundation in the ground). Engineered based on the load, they were were buried and secured before the suspension cables were brought in.
Step 4: Build the Cable System
The suspension cables and stringers were cut and assembled off-site. Because of the Golden Gate style, the stringers each had to be a specific height to keep the deck level, actually, slightly crowned.
Step 5: Consider Resonance
The stringers were also spaced to deal with harmonic resonance. Though keep in mind, it’s a suspension bridge and it will move when you walk on it. Whee!
Step 6: Span the Cables and Stringers
Use of a truck on one side of the creek transported the cables across the creek with the stringers rolled up so they didn't tangle. The cables were secured into place.
Step 7: Add the Support Beams
We used our patented Cable Locking System to attach the beams. This system allows for assembly “on the fly” and easy repair/replacement of the beams (joists) if needed. Temporary planks were set out as we worked our way across the span.
The movie shows exactly how the cable locking system works. The magic of the system is the reversed keyhole arrangements between the two components.To note, the email and website given at the end are no more. YouTube doesn't let us edit videos.
Step 8: Add the Decking
Once the beams were in place, we added decking.
Step 9: Now We Can Get to the Other Side and Stay Dry!
This bridge has been our access across the creek to get to our spring for many years, and is holding up great through several major floods. A couple of trees have hit it, but it wasn’t phased. We recently adjusted the turnbuckles on the dead men cables to pull up the slack in the deck from tree hits.
Step 10: For More Information...
Note that all photos and illustrations are from our book, Building a Small Cable Suspension Bridge with the Cable Locking System. The book is easily found on if you look it up, and our blog with more info is Hopefully this is enough information to get you inspired!
    • Trash to Treasure
      Trash to Treasure
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    Great bridge looks fantastic. On your cable locking system, how are the cables terminated (what tools were used) and what is the breaking strength of that termination. The keyhole idea is ingenious but is there any chance of the end wearing out and slipping through? On your specific bridge and out of curiosity, do you think it would support a riding lawnmower or a bicycle?
    Thanks! And thanks for your questions.
    I terminated the 3/16 cable (aircraft cable rated at about 4200# breaking strength) with aluminimum swagged end sleeves. According to some suppliers, a swagged end sleeve will achieve 95% of the breaking strength of the cable it is placed on (95% of 4200# = 3,900#). But not trusting everything I read, I decided to place 2 of them together, one right next to the other; besides they are cheap. The tool is a hand operated crimping tool - I made 3 craimps per sleeve.
    I would suppose there is a chance of the end crimp wearing down. My bridge has been in place for ove ten years and there are no signs of visible wear (as mentioned above, there are two stops to wear down). This is a private bridge with not a great deal of traffic. If this were a public bridge I’d probably use a machine swagged ends on the cables.
    As I have noted above, the breaking strength of the single (one side) cable is about 2 tons. That would be 4 tons for each support beam. The deck is the only limiting factor for a riding mower. I didn’t build a deck that would support it - the 2x wood deck is not strong enough nor is it wide enough. I had considered building the bridge to do just what you asked, but didn’t find a satisfactory or affordable deck material without moving the beam to beam span closer together. I wanted a flexible steel or aluminum deck but fairly light weight for handling and installation. I’m still working on that for a future bridge. But you could take a bicycle across, if you have good balance on a moving bridge! — Marvin
    Here's a photo of a swagged end.
    I have a dream of building a Simple suspension bridge between two neighborhoods in my city in Israel, Maale Adumim, built on two hill slopes separated by a ravine I see that the longest such bridge in the world was recently completed in Switzerland, not much longer - about 500 meters longer (1620 feet). Is this WAY above your pay grade?
    I'm pretty much retired these days, but hopefully you can find someone to help with your project!
    this is spectacular!
    Thank you, it was fun to build and even more fun to cross!
    This is awesome! I was hearing Tangerine Dream as I read this...
    Thanks! I had to look them up, even though I'm a child of the 60s. :-)
