If you are not used to working with powertools ask someone who knows how to use them.
After building this turbine you will still need you fingers so.
PLEASE BE CAREFULL !!!
Remove these ads by
Signing UpStep 1Tools and parts
- Jigsaw and or band saw
- Hand saw
- Lathe
- Drill press or hand drill
- Drill bits
- Screwdriver
- Tab tool
- Ruler
- Pencil
- Compass
- Sanding paper
- Vise ( it makes work more easy)
- Wrenches
- 2 clamps
PARTS
- PVC pipe
- Waterproof wood "concrete form plywood is the best"( if you don't have that you will have to protect it with a coating )
- 2 Bearings ( bottom one needs to be able to handle a load )
- Grease nipple
- Wire rod ( 2 sizes ) ( 1 big one and 4 small ones ) ( Stainless if possible )
- Bolts and washers ( 2 sizes ) ( Stainless if possible )
- A piece of 40 mm round aluminium ( Alloy ) ( it will hold the bottom bearing )
- 2 Angle irons
- 3 eye screws
The plan was to mount the generator at the bottom
The turbine was not strong enough or i had to mount a really small one
I'm not using this turbine anymore
It was my first turbine
I'm working with my uncle on a new turbine
Greetings from Belgium
Erik
Darko
First of all, happy new year and the best wishes
I tried several generators on it but it never seems to be having enough tork.
I probably tried with to heavy motors connected to it.
If you keep the permanent magnet motor small enough i'm sure it will work well.
Just get the turbine high up.
I'm not sure if this design will have enough strenght to make it 2 meters high.
Ofcourse you can try it but i'm scared it might get a bit wobbly. ( unbalanced at higher rpm )
For now i'm working on a other wind turbine with my uncle.
We hope to get it up soon now, maybe this week or the week after.
We use a dynamo from a bicycle and it produces about 0,4 amps and 25 volt
If we connect it to a battery it will balance itself and go to 13 volts or so.
divide that by 30 days and again by 24 hours, and by 1000 watts/Kw.
That the average wattage you draw. I'd expect that to be between
1000 and 2000 watts. Since that's your average, you probably want
between 4 and 10 times that as your peak output, depending on how
regular your wind is.
http://www.instructables.com/id/DIY-1000-watt-wind-turbine/
Greetings
Erik
I'v been working on some other things for a while.
I'm working on the generator for my Lenz turbine.
it will be a axial flux generator.
I'm thinking of making a smaller one for this turbine too.
Greetings
Erik
Erik
