3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Building a Vertical Axis Wind Turbine ( VAWT )
Step 6Making the center wire rod to size
First you mount the top of the turbine just as you did the bottom in the step before.
Pay attention to the markings you made on the sides of the disks when they were still clamped.
This way the same cuts will be nicely on top of each other and the turbine will wobble less after its finished. You might want to use a hammer and a little piece of wood to not damage the blades or the disk when you hit it. Make sure the blades fit tight and the 4 little rods are in the right place. It was not a easy job. Good luck. hehe
Now we will fit the big wire rod with the necessary bolts and washers.
What were going to do now is mark where we will cut of the wire rod.
The first picture is a view from the bottom disk.
I put 2 bolts there and they will rest on the bottom bearing.
I left the wire longer there so i can connect a generator of some sort there.
The upper disk is the second picture and the rod will be cut shorter.
On that side we will only have a bearing to balance the turbine when its in place on its frame.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:rikkiesix(Erik's Wind Shed)
