3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Building a Vertical Axis Wind Turbine ( VAWT )
Step 8Making the holder for the bottom bearing
The bearing i used is made out of 3 parts as shown on the first picture.
This bearing is made to cope with vertical weight.
If you watch closely you will see that the 2 disks don't have the same inner size hole.
The disk with the biggest hole ( the one on the right ) is the top part of the bearing where the turbine will rest on.
I cut the hole out on the lathe just the diameter of the bearing. Do this according to the size of the bearing you will use.
Don't make the hole to deep!
Make sure that the top part of the bearing is just sticking out of the holder.
The reason for this is that the top ring will spin together with the turbine and would otherwise rub against the inside of the holder and would slow your turbine down and wear it out quickly.
You will also have to drill a hole through the bottom of the holder so the wire rod can fit through.
Make it slightly bigger then the size of the rod so ones its mounted it will not tough the sides.
You have seen that this bearing has no grease in it so we will have to install a grease nipple.
Use a thread cutting tool to do so.
First drill a hole according to the tread and the nipple size you will use. Mine was M6.
Use some cutting oil because your cutting in aluminium and otherwise it will get all rough on the inside. Run the cutting tool for about 1 turn and then run it back for half a turn. This way the metal is cut inside and you will not brake your tool. Use the 3 stages of cutting till you reach the right tread.
2 comments
Mar 18, 2010. 10:12 PMvamshik says:
It looks simle but effective. what is the rated capacity in terms of watts?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:rikkiesix(Erik's Wind Shed)
