3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Building a better Guinea and Feather
Step 8Bottom cap block and object platforms
The Bottom cap block is also similar to the Top cap block except for two 1/4"-20 bottom-tapped holes to mount the object landing platforms. The objects in the two vacuum tubes will land on these platforms, just above the top face of the Bottom O-ring block. Without the platforms, the objects would land out of sight below the right angle brass fittings. The platform outside diameters are smaller than the 2.25" tube inside diameter and they are drilled through the top and sides to allow air to be pumped out of the tubes.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
43
Author:sbtroy
I have B.S. degrees in both Physics and Electrical Engineering. I do Lecture Demonstrations for the University of Washington Department of Physics. I don't check my messages here so please email me ...
more »
