Step 8Set up drive train
If you're keeping the gears, you'll want to set up th drive train before finishing the seat stays,
Make up your top bottom bracket, and put on of the pair of drive cranks on the left side. pull the non drive crank from the bottom bike, and replace it with the other drive crank. make up a chain long enough for to reach, then adust the seatpost to tension the chain. while adusting chain tension you'll probably knock the alignment off, ust get it back as well as you can.
Add Comment
