The d-touch drum machine software can be freely downloaded from http://www.d-touch.org/audio/
Here is a video briefly showing the finished product and a very quick overview of the making process:
Remove these ads by
Signing UpStep 1Get the ingredients
- a computer running Windows, OS X or Linux
- a webcam
- a printer (ink-jet for best results)
- A4 paper
- 5 or more A4 sheets of thin printable cardboard (e.g 180 g/mm2)
- 4 pieces of size A4 or bigger of corrugated cardboard 3-4 mm tick; this can be obtained from used cardboard boxes
- paper & cardboard cutting tools (scissors or knife)
- paper & cardboard glue
- adhesive tape or masking tape
- the d-touch drum machine software downloadable for free from http://www.d-touch.org/audio/
- a network connection (this is for our research, see above)
- lentils or other small beads
![WORLDS CHEAPEST VIRTUAL DRUM at $10 [ Rs.500] - using pc ( no drum module required )](http://img.instructables.com/files/deriv/FA7/71UR/GUI0ZWAC/FA771URGUI0ZWAC.SQUARE.jpg)
However, did you notice that we now have another application out? It is a sampling sequencer, it's available at the same conditions as the drum machine. There you can record your samples live, or you can also change the wave files. I have to say that changing the waves is not yet very smooth, you have to directly change the .wav files, and make sure you keep the same name and format (just open one of the old ones and see, the rate is a bit unusual).
Let us know if you give it a try and if it works for you..
bye
If anyone is having issues, they are being discussed on http://d-touch.org/forum/audio/.
Short summary (feel free to follow up here):
- activation problems? on vista you may have to disable "User Access Control" ("UAC is the the thing that grays out your whole screen to pop up a box") (thanks Jay)
- multiple cameras? on any WindowsOS if you have 2 webcams the external one is automatically selected, if you have >2 it may be tricky -- one workaround is to temporarily disable the cameras that you do not want from windows control panel (thanks Gasman)
