Step 3Putting it together
Once everything checks out and the frame is squared, mark your holes for the L brackets making sure the framework doesn't get too jarred out of alignment. Take note as to how square your brackets are. They might need a little bending. I went with some pretty hefty hardware, so it went fairly smooth for me.
Using a drill bit roughly smaller than the barrel width of the bolt, drill your holes. You want the screw to bite into the the wood, but not split it. Using lag bolts this size would definitely split your wood.
Once all my drilling was done, the fun part came. I didn't have a driver attachment for the hex head, so I had to use the good ole socket wrench for 48 bolts. Make sure you do a little at a time to ensue squareness before final tightening.
Add Comment
