I designed a piece of jewelry, made a mold using the lost wax technique, cast the piece of jewelry then set a stone in it. All the materials are easily obtainable. It works with precious metals but if your on a budget and even cheap jewelry from Wal-mart can be melted down and used. It makes an attractive piece that carries a certain homemade charm (no pun intended) without the tacky homemade look. I made a necklace, but the technique can be applied to rings, bracelets, earrings, glasses, small machine parts... really the only limit is your imagination. (although for highly complex designs with many small or detailed surface features you may need to build a centrifuge which I describe near the end)
Remove these ads by
Signing UpStep 1Gather Materials
Furnace
-1 Quart paint can
-10 LB bag Quickrete
-Butane torch
-1" x 7" pipe
-1/2" diameter steel pipe
-3/4" diameter copper pipe caps
-10 Ga. Steel wire
-Brick (without holes)
-Something to mix the concrete in
-Something to mix the concrete with
-Small piece of cardboard
-Masking tape
-Hand tools
-Dremel (optional)
Molds
-Faster Plaster
-Water
-Source of wax (unscented candles work well)
-Carving tools (exacto knives work well)
-Small wooden blocks
-Heat source (microwave works well)
Casting supplies
Any metal with a melting point under ~2000 Degrees F
Small fire to heat mold, camp stoves work great
Pliers
Finishing Tools & Supplies
-Polishing compound
-Dremel with: Polishing Wheel, Engraving Bits (optional), Diamond Cutting Wheel (to cut stone)
-Fine sandpaper (if casting is rough)
-Claps, rings, fasteners, chains etc... (available at most craft stores such as Michaels or Hobby Lobby)
-Marine grade epoxy (to set stone)
-A box to put finished jewelry in (optional)
http://www.rubertones.com
Would the crucible need to be a different material?
In the FAQ it says that to repair a fireplace they have quikrete that can withstand up to 300 F, but isn't that kinda low for a furnace?
In your materials you list a 1"x7" pipe. I assume that this is the pipe that goes inside the quart can to make it hollow.
But my quart cans are only 5" deep. Are you using can with another dimension?
And a 1" diameter hole seems way too small. From your last picture on Step 2, if that small copper cap is 3/4" in diameter, I'd estimate that your inner hollow is at least 2" in diameter. Would you say that sounds right?
Thanks!
(I'm setting this all up in my workshop right now, and keep getting confused by the various dimensions listed)
Also, I'm a little confused by the direction the bottom pipe is supposed to go in. In your pictures on step two, it looks like the pipe (and the blowtorch's flame) go straight towards the center of the furnace.
The pipe is supposed to be approximately tangent to the wall of the inner part of the furnace. The idea is to cause the heat to convect around the crucible rather than heat up a spot on the side of the crucible thats touching the blowtorch. My implementation of it sort of failed (e.g. I didn't get the pipe orented properly) and as a result I burned a hole through several crucibles because of the intense heating in one spot. Basically follow what I wrote and tried to explain, not what my picture showed ;)
One alternative is to steam cast. Instead of putting your wax into a foam cup, put it into some sort of metal can (soup can with top and bottom removed works) - this is called the casting flask. Also, make tubes of wax and weld them onto the back of your wax piece (they are called sprues) at multiple points to allow the metal to flow evenly. The farther the metal has to go, the less detail you can put into the piece. Also, at the other end of your sprues, you want to make a small bowl shaped area to hold the metal as it melts (this will act as your crucible now). But more importantly, this depression (called a "button") holds in extra heat so the metal will stay liquid longer as it flows through the mold. Pour your plaster around your piece and cure it. Burn out the wax (heat it in your furnace until about 500 degrees, or until all smoke has stopped coming out. Place the metal to be cast into the button now and put it back into the furnace. Let it all get nice and hot, melting the metal in the button, or getting it close. Then pull the whole thing out and place it on either a firebrick or on some concrete. Heat the metal up more using a torch - you want it nice and liquid, and you will see patterns swirling around - that means it's hot enough now.
Now comes the fun part. Wear some type of gloves while doing this - I use gardening gloves that are soaking wet, stuffed with wet paper towel in the palm - this give me good control and still gives some protection. While you were waiting for the metal to melt, you have prepared a lid from a pickle jar, or spaghetti sauce jar (metal, threaded lid) by placing a couple of folded paper towels into it and getting it wet. Take this wet jar lid/paper towel combo and place it on top of your casting flask and melted metal (which is still liquid). Press down HARD - use your body weight! You will hear the steam hiss, and hold it down for 30 seconds to 1 minute. Congrats! Your piece has now been steam casted! I like to throw the whole thing into a bucket of water and the plaster just crumbles out, but remove from the plaster and finish as you see fit.
A note - it helps to have more metal in your button for steam casting than other methods - the button is a heat battery, basically and the steam will consume part of that. So to compensate, melt more metal when you cast this way.
I hope that helps you in you casting fun! It is certainly the most fun way to cast for me.
http://mechanicallyinclined.net/page_the_ring.html
