supplies needed:
1.26w weather proof solar panel $30.00 (cabelas)
12v 7.5amp rechargeable sealed lead-acid battery $30.00 (radioshack)
12v socket $11.00 (walmart)
cooler $8.00 (walmart)
nuts/bolts $2.00 (walmart)
wire plugs $2.00 (walmart)
super glue $1.00 (dollar store)
TOTAL: $84.00
w/tax around $90.00
tools needed:
drill
utility knife
screw drivers
wire cutters
Step 1: Cutting wires and holes
Step 2: Assembly
Next the 12v socket was threaded into place.
super glue was applied to the nuts and the 12v socket threading to insure vibration would not cause any thing to come loose.
After the glue set I crimped the wires from the panel and the 12v outlet to quick disconnect tabs.
the final step was dropping in the battery and plugging in the wires.
Step 3: Testing
Step 4: Accessories
If you have any questions or comments feel free to email me at:
dale_humphrey_jr@hotmail.com
Visit Our Store »
Go Pro Today »
So it will not over charge if the proper panel voltage is applied. The panel likely has a rectifier so that it does not discharge when the sun goes down.
still looking for an inexpensive way to run one in an emergency.
Is there a way to hook up 2 of these to give double the power?
janei
I also have working solar lantern (uses L.E.D. bulbs) that I got from tractor supply for $25 + tax that has a 5.5 volt panel. I don't have (or really want) electricity per se, but don't want to run a propane heater to the chickens. Incandescent bulbs provide heat, in fact I think they provide more heat than light.
For about $80 I can put a deep cycle marine battery on lay-a-away at Tractor supply. 12 v. but I'm not sure about the wattage or the ampage.
Makes me think a lot of a link I saw recently to build a solar generator for less than $300:
http://www.rain.org/~philfear/how2solar.html
In the above link they emphasize deep-cycle batteries. Depending on the size of said container/cooler, I would think such a battery would work great in your instructable.
Very nice!
