Remove these ads by
Signing UpStep 1Parts List
2x6. About 24" long
1/2 NPT Steel Pipe. 2 pieces @ 8" long.
1/2 NPT Steel Pipe Flange qty 4
1/4-20 x 1" Flat head screws qty 16
1/4-20 Nuts (I used T-Nuts) qty 16
Cost To Build. I had everything except the plumbing parts which were about $18.
Duration: About 2 hours not including the decorating time.
Now I ride muni (mountain unicycle) and sometimes do some trials - it's great fun
* v *
Also, I just left 2 by 6 pedal solid instead of glueing the two cut pieces together. I just wallowed the pedal out from each side with a 7/8 in. paddle bit. I think this made the pedals stronger.
I put sand paper on the wheels facing up and it worked good on carpet but the glue I used to glue it to the wheel got a little lumpy at times so make sure you get all the lumps out. My suggestion would be to find some kind of rubber to fit around the wheels to get better traction.
Tires....
My Legway used plastic edge moulding. It works, but degrades quickly. My Streamroller used split rubber hose. That has held up to a lot of riding.
The DuoPed!
