Step 11The base, step eight - Lather, rinse, repeat
Once the stretchers and legs have been connected, flip the assembly upside down, and install the levelers. Then flip it back upright.
Next is the shelf. Start with the 24x48" piece of MDF. Clamp this on top of the base, and pencil in the outside of the stretchers and the inside angle of the legs. Flip it over, pull out your trusty cutting guide, and cut it to width and to length. Cutting out the angles is simple, with a jig saw. It's not much work with a hand saw. If you took enough care with supporting blocks and stops, you could probably do it with a circular saw. Since I did have a jig saw, I used it.
Add Comment
