3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Building a real woodworker's workbench
Step 29The vises, step three - gluing up the jaws
With the bench assembled, and the vise bases mounted, it's time install the vise jaws.
On a vise, the surfaces that hold whatever it is they are holding are the jaws. I'd intended to install the front vise so that it uses the edge of the bench top as the stationary jaw, so for it I only needed to build the moving jaw. For the end vise I needed both stationary and moving.
The jaw for the front vise needed to be 10" long - to span the distance from the leg to the end of the top, 1-1/2" thick - to allow for benchdog holes to be drilled in it, and 5" tall. The end vise was mounted 3/4" lower than the front vise, and the screw and guide rods were thicker, so its jaws needed to be at least 6-1/2" tall. Again, they needed to be 1-1/2" thick to allow for benchdog holes, and 23" long to span the width of the bench.
Nominal 2x6 dimensional lumber is actual 1-1/2x5-1/2". My local home store stocked finished clear oak 2x6 in two foot lengths, at a fairly hgh price per board-foot, but a quite reasonable actual price considering my local lumberyard doesn't sell boards in 2' lengths.
The home store didn't carry oak 2x8s. But it did carry oak 1x8s in four foot lengths. Two of these glued together would give me the stock I needed, at a lower cost than buying an eight-foot length of 2x8 at the lumberyard.
The process of cutting them up and gluing them together is straightforward. Once glued, I routed the bottom edge of each straight, then started fitting them.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
58
Author:jdege
