3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Building a real woodworker's workbench
Step 31The vises, step five - bolting and routing the jaws
  • last photo ←
One you have the vise jaws shaped so that the vise moves freely, mark and drill holes in the fixed jaw for the bolts that will hold it to the bench. With these drilled, reassemble the vise and mark the location of the holes with an awl. Disassemble the vise and drill the holes through the stretcher, then reassemble the vise and bolt the inner jaw in place.
With the inner jaw fastened to the bench, I used the router to flush-trim the jaw to the benchtop, across the top and down the sides adjacent to the top (stopping short of the discontinuity between the top and the legs). I'd thought this would be the best way to match up the jaw against the top, but I'd not do it this way again. It was very difficult to hold the router tight against the face of the jaw, and the result was a surface that wasn't as even as I had hoped.
Mark and drill the holes and countersinks that will hold the outer jaws to the vises (for both the front and the end vise).
Remove the jaws and route the edges that you could not route while they were still attached. Then use a roundover bit on all of the corners except the inner edge of the inner jaw of the end vise. Give everything a lite sanding, and apply Danish oil to the inner surfaces of the jaws. (By "inner surfaces", I mean those surfaces that will not be accessible when the vises are assembled - the inner surface of the inner jaw, that bolts to the bench, and the outer surfaces of the outer jaws, that bolt to the vise plates.)
Assemble the vises, for the final time. You'll not be taking them off again, so tighten everything down, and attach the endplate to the ends of the screw and guide rods. Then mark and drill benchdog holes in the outer jaws inline with the benchdog holes in the top. Generally, through-holes are preferred for benchdogs, so that they don't collect sawdust and gunk. With these vises, that isn't possible, there are screws and guide rods in the way. I drilled them just deep enough to hold a Veritas Bench Pony (their reduced-height benchdog), without it sinking to where I can't get a grip to remove it. Rockler sells some very inexpensive plastic benchdogs that can't be adjusted for height, and aren't as strong as metal or wooden dogs, that I intend to keep in the holes full-time, to keep sawdust from collecting in them.
With the holes drilled, finish them with a few coats of Danish oil.
Finish the whole thing up by applying a coat of paste wax to the top.
5 comments
Oct 17, 2011. 9:20 AMshuja.shaher says:
ten on ten
a perfect instructable/tutorial/guide
hats off
and
thankyou
Jan 10, 2011. 4:42 PMvincent7520 says:
Perfect ! …
Got a lot of insights that will help to make mine when time comes (probably next year)
Thank you again for your contribution.
Oct 19, 2010. 6:40 PMDELETED_gustavoindustry says:
(removed by author or community request)
Jun 24, 2010. 9:00 PMTazo says:
Really great, I´ve been looking for a work bench design for a while now and I finally got exactly what I was looking for!!! Thanks a lot
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
58
Author:jdege
