Step 6The Base, step three - sanding the parts
So I determined to clean up the boards, to remove the stamps and splinters, and to prep for a finish of some type.
There's only the one picture for this step, but it was by far the most time-consuming.
I used the hand screws again, to hold the pieces. I used a belt sander to remove the surface problems, then used a small random-orbital sander to remove scratches left by the belt sander. In total, it required five passes - 50 and 80 grit on the belt sander, 100, 150, and 220 grit on the orbital.
My advice? Don't do this. If you have jointer and a planer, use them. If you don't, seriously consider using dimensional lumber that has already been planed and sanded. If you are going to try to clean up construction lumber by hand, using a hand plane is a lot faster and more pleasant than using a belt sander. Except, of course, that to do a good job of planing a board you need a solid bench to hold the board, and you don't have a bench, yet.
Me, I'm stubborn, and nearly always insist on doing things the hard way.
Add Comment
