3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Building a real woodworker's workbench
Step 8The Base, step five - Trestle dowel holes
Drill the stretcher dowel holes
Drill a pair of 3/8" holes in each end of the short stretchers, just over half of the depth of the dowels, using a brad-pointed bit. These stretchers already have a groove running their length, centered on the bottom edge. Precise placement isn't necessary, but keeping track of which part is which is. We need a hole in each end of each stretcher. Take care to keep these holes square, you don't want them running at angles.
Mark the leg dowel holes
Lay a leg flat on your work surface, with the countersink side of the thru-holes down. Stick a piece of threaded rod in each hole. Take a stretcher that is marked to have one end adjoin the top of this leg, stick a dowel center in its dowel hole, line it up against the leg, using the threaded rod for positioning, You want the top of the stretcher to be even with the top of the leg, or just slightly above it. Give the end of the stretcher a whack with your rubber mallet. This will leave a mark indicating where the matching dowel hole in the leg needs to be drilled. Repeat with the lower stretcher than adjoins this leg. Then repeat for the other leg that will form this trestle, and the other ends of the two stretchers.
Drill the leg dowel holes
When you have both legs for this stretcher marked, drill the other dowel holes at the marks. Again, take care to make the holes square.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
58
Author:jdege
