Step 9Testing, testing
Time for a proper test. Do a test batch of whatever stinky project you built the hood for. This will produce much more stink than just an open container, so go around and check for leaks one last time. Once you are satisfied that it's sealed, you're done! Enjoy being able to do your stinky projects indoors!
(Aside: As I mentioned earlier, the small duct we had installed at first could not handle the full flow rate so the face velocity was too low to keep everything in. It still worked reasonably well, but the smell of the resin was perceptible.
The volume of air that a duct can carry scales with cross-sectional area; our duct is circular so the area scales with the square of the diameter. That means that using a 3" duct rather than 4" cuts the diameter by 25%, which cuts the duct capacity down by about 44%! Oops, an embarrassing oversight... I ended up having to go back out and find a 4" duct after all. Once I replaced the small duct with one of the proper size, we tested it again... success! We could no longer smell the fumes!)
And another thought. Why not cut out most of the thin angled front part of the hood (I would leave juts 5 inches on each side for fitting over the wooden box and stability) and glue another plexiglass sheet cut to size, so your wife can look straight down when working, without cranking her neck or stepping back to look and letting fumes escape through the front opening (read here: use silicone to stick the plexiglass to the metal :-)
