3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Building a strong flexible bicycle trailer coupler.
This Instructable will demonstrate how to build a coupler that can be used with a variety of bicycle trailers that will turn and rotate in all possible directions: up and down, side to side, and rotate to allow the trailer to "tip" from side to side during travel.
I had seen a previous Instructable that relied on a single swivel caster to allow the bike trailer to turn from side to side and move up and down vertically, but then suggested a "pipe and sleeve" sort of coupler to allow trailer rotation (tilt). Although that proposed Instructable would work as suggested, it seemed to me that, with the investment in a second swivel caster mounted on a fixed frame at a 90 degree angle to the first swivel caster, you could very easily attain flexibility in all 3 planes of motion: (1) allowing horizontal turning side to side; (2) allowing the trailer tongue to move vertically up and down; and (3) allowing the trailer to "rotate" - to "tip" from side to side.
The proposed plan allows this movement in the following ways: (1) one caster wheel is trimmed flush on one side to allow it to be bolted horizontally to a point on the bicycle, and then the caster wheel frame is again reattached to the wheel, allowing the caster to turn horizontally on the bicycle mounting point; (2) the caster swivel on this first caster also allows the trailer tongue to move up and down vertically; and (3) the caster swivel on the second caster allows the trailer tongue to "rotate/tip" from side to side during travel independent of the vertical angle of the bicycle.
The parts you will need for this plan are simple:
(1) Two swivel casters of sufficient size - I used 2" swivel casters that are available at local hardware or home improvement stores for about $4 apiece.
(2) A frame to attach these casters at right angles to each other. I purchased a heavy duty right angle galvanized construction connector (i.e., Simpson), readily available from local lumber yards or construction supply stores, also for less than $4.
(3) Sufficient short bolts and locking nuts to attach the caster to this frame. I used eight 1/2" long 1/4" bolts and nylon-insert lock nuts to bolt the casters to the galvanized construction connector.
(4) Appropriate hardware to attach the coupler both to your bicycle and to the trailer frame. I fabricated an extended mount on my bicycle (see step 2) that is shown as the red square tubing in the picture illustrating this step. The trailer tongue is the black section of square tubing also shown in the same picture. I used the caster wheels as described in the following steps to attach the trailer coupler to both the mounting point on the bicycle and to the bicycle trailer.
(5) Though purely optional, I wanted to be able to quickly attach and detach the bicycle trailer from the bike; and therefore replaced one of the two caster wheel bolts with a similar diameter and length locking hitch pin that slips through the caster wheel bolt holes and the caster wheel bushing (see ring on top of this locking hitch pin inserted through the caster on the right side of the accompanying photo). This is also a hardware store item and should cost less than $4.
Step 1Determining or building an attachment point on your bicycle frame.
Although many bike trailers attach to the left rear hub of the bicycle, this attachment point prohibits the trailer from turning a full 180 degrees around the rear of the bike. I have a long wheelbase recumbent bicycle that already is difficult to turn in a tight radius - I did not want a trailer coupler that was not fully flexible and would not be able to allow my bicycle trailer to turn freely behind the bicycle.
In order to move the pivot point between the bicycle and the trailer to a point where it would allow the trailer to turn from side to side as far as possible, I attached a 3/4" X 3/4" length of square channel steel tubing that fastens behind the main chainwheel of the bicycle, and is firmly clamped with several coaster brake frame clamps along the left chainstay to the left rear dropout (hub), and then extends past the rear dropout past the rear tire of the bike. I painted this piece of tubing the same color as the bicycle and it remains on the bike at all times.
At the very end of this piece of added tubing, before it was installed, I drilled and attached one of the two caster wheels. This caster wheel was cut flat on one side with a Dremel tool cutting wheel to facilitate its attachment to the tubing, and was drilled though vertically to allow it to be bolted to the tubing. The caster wheel frame is then attached over the caster wheel and turns around the caster wheel (much in the manner it was originally designed) and allows the trailer to turn left and right freely.
29 comments
Mar 13, 2012. 3:53 PMplasticorange says:
do you have a photo of the attachment to the bike? you mentioned you have 3 separate axes ---- I assume the 3rd axis is at the attachment to the bicycle?
Thanks!
Aug 24, 2011. 7:20 PMbilly508 says:
Good job. Your idea offers a effective solution to a difficult problem. Simple,Cheap, and effective. I like it Thanks.
May 24, 2011. 2:57 PMMuggsinSD says:
Weblar, I'd love pictures of how you attached this to your bicycle. I looked at your other posts and didn't see one and am not happy with most of the other ones I've seen. I love this design, and can only imagine how cool your attachment point is!!!
Apr 15, 2011. 11:11 AMSalvage Steve says:
VERY SLICK!
Apr 3, 2011. 7:05 AMspark master says:
elegant,
off the shelf parts
Feb 18, 2011. 9:03 AMKWHCoaster says:
Great idea to use what appears to be a folding golf cart for the trailer chassis & wheels. I haven't golfed in 15+ years and I have a folding golf cart in my storage locker that now can be re-purposed!
Jan 22, 2011. 9:39 AMBillBiker says:
This is the 2nd I have came across by you weblar! Indeed yet another awesome 'able. I'm currently working on a project having to do with a bike trailer. I may use part of this in my project. Thanks
Jan 24, 2011. 5:22 AMBillBiker says:
Yes definitely and my other half likes the idea I do not have to go buy "new stuff" lol. This site is invaluable!!!
Dec 4, 2010. 7:28 AMyel3an_ha says:
U Could've Done It With 1 Wheel Only!!
Mar 7, 2010. 3:51 PMfelmont says:
I love the design!!!
Question - before I embark on building this hitch, I'm a bit sceptical about the amount of load that will be put on the the "swivel" part!
Since the whole trailer will be pulled on the pivot, it will be pulling "through" one of the swivels (the swivel on the second caster, which provides the rotational movement)...
Is the ball bearing mechanism and plates holding it together really strong enough to hold out over long distances and time? Seems like it might just bend and give out!! Which inclines me to use the D-bolt and eye-bolt hitch instead.
See my progress so far for pics of both of my hitch ideas (second one is inspired from this page!) www.flickr.com/photos/48007949@N03/sets/72157623536962194/
Aug 29, 2010. 4:13 PMbo88y says:
These casters are designed for eccentric loading-- when used in the usual way, the caster axle is offset from the swivel axis, and these casters look like they're rated in the 200 lb. range. And while towing subjects the bearings to more jerks and shocks, I doubt you're getting anywhere close to the rated load on the bearings. The weak link, I think, is the attachment of the caster to the red square tubing, but even that seems strong enough.
Jun 25, 2010. 12:13 AMbikerusl says:
At this point you might as well go for something purpose built that will be cheaper and less work: http://www.midwestcontrol.com/catdisplay_short.php?pg=119 Use 12mm or 0.5" for heavy duty trailers (>300lbs) and you could use smaller like M10 for a more average 200lb trailer. The only problem with midwest is you have to buy bulk.
Center for Appropriate Transport Eugene has these kind of hitches http://hpm.catoregon.org Also if you are in Vancouver, BC I just boult 15 of them and I don't need that many so I could sell a few to anyone interested at cost - or I am going to make a kit like HPM CAT has which has some pre-made parts (less DIY) bicyclefamily.ca
May 1, 2010. 9:49 PMjoshfromga says:
hmm... i like your design. it looks effective, but i saw something on the road a few months ago that was a bit simpler and gave an additional axis of rotation for the trailor. it was an older fellow who took 2 large casters, took the wheels off, and ran a single axle through both of them. it looked like the quick mock-up below. anyways its just an ideayou can play with and see if it meets your needs.
May 22, 2010. 5:48 AMjoshfromga says:
yeah, the older fellow who built it had it attached to the cargo rack over his rear wheel.  he offered to sell the whole setup (minus the bike of course) for 80 dollars. didn't have the cash at the time though.
Oct 2, 2009. 6:28 PMgodspiral says:
a big improvement would seem to be able to get rid of the wheel and dril the caster axel directly through the red bar. Stress is amplified the further the pivot point from the caster bearing, and its not obvious the caster will stay bolted.
Sep 30, 2009. 1:48 PMTinworm says:
very clever indeed! :)
Jun 23, 2009. 11:50 AMdepotdevoid says:
Nice idea! I like the final product, and wish I still had my bike trailer to try it on!
Jun 23, 2009. 5:46 AMlieuwe says:
heh, the commercial bike trailer i have just uses a spring-thingy with a rope as backup for when the spring fails...
Jun 22, 2009. 5:53 AMrimar2000 says:
Very good idea.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:weblar
Intelligent tinkerer who would rather design and build exactly what I want rather than purchase something designed for the masses.
