To be able to experiment with the antenna and to tune it to different frequencies, I decided to build a antenna where the elements can be changed in length.
Looking around the Internet and the "Rothammel" I found that the "sleeve antenna" is ideal. It easy to construct and the elements can be build using expendable antennas from r/c remote controls.
Remove these ads by
Signing UpStep 1: Mechanical construction
Two antennas will be used for the sleeve antenna, being a vertical polarized dipole. The antenna will be small because it is build for a frequency range 470Mhz to 740Mhz. This makes the mechanical construction easy. Just use some heat shrinkable tubing to fix them.
The antenna can be tuned by changing the length of the dipole elements. The antenna can be mounted using a vacuum cup because it doesn't wight much.
All measurement is done in the metric system using meters not inches ... I am German ;-)
Material:
- two r/c remote control antennas
- about 40cm RG-174 coax cable (don't use to much because the damping of this cable is high)
- coax connector that can be plugged into your receiver, i used a bnc blug
- vacuum cup, for easy mounting
- hexagonal brass nut, size M3 (in my case, could be other size for you)
Tools:
- pliers
- soldering iron
- solder
- sharp knife
- hacksaw
- small screw driver
- fine sanding paper
- maybe some silicone spray or oil
Visit Our Store »
Go Pro Today »
http://www.cnet.de/praxis/wochenend/41001557/die_beste_eigenbau_dvb_t_antenne_doppelquad_fuer_5_euro_basteln.htm
I build 3 of those today and the just work PERFECT.
100/-98% on three different TV-sets all over town.
You have to use their calculator with your region's max/min frequencies - this will give you the desired quad-side-length.
Make sure to make everything flat and rectangular, small dents are no problem.
They also have projects for multi-quads and an amplifier for about 3$.
(We all live in city center / like 3km away from the broadcast-antennas. If you are further away, you might have to use an amp.)
Also keep in mind, that this antenna has to turned into the right direction - although here it's enough to chose either the wall behind the TV or the 90° corner next to it.
You can check out more information here, search for "Vertical polarization is most commonly used when it is desired to radiate a radio signal in all directions over a short to medium range." if you are looking for just that.
