3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Building an Aquaponic System
Aquaponics is the combination of aquaculture and hydroponics. In aquaponics, the nutrient-rich water that results from raising fish provides a source of natural fertilizer for the growing plants. As the plants consume the nutrients, they help to purify the water that the fish live in. A natural microbial process keeps both the fish and plants healthy.
Step 1Acquiring the Materials
To build this system you will need to construct two grow beds, two fish-food growing tanks, a fish tank, as well as a stand to elevate the fish food tanks.
To build the grow beds you will need:
5  8' 2x4s
1  4'x8' sheet of 1/2'' plywood
4  8' 4''x4'' posts
8  3/8'' carriage bolts with washers and nuts
555' sq. of pond liner
2'' deck screws
small grade pea gravel
2' permeable bags (coconut fiber bags and vermiculite)
To build the fish tank and fish-food tanks you will need:
2  55 gallon drums (plastic)
1  little giant 200gph submersible pump
2' sq. of metal mesh filter
8' of 3/4'' flex hose
1  1'' 8' PVC pipe
6  PVC fittings
2  90 deg. PVC fittings
1  'T' PVC fitting
To build the stand you will need:
Scrap steel (we used 3'' steel pipe)
Welder
Grinder
Spray paint
5 comments
May 9, 2012. 9:03 PMvgreen89 says:
I looked up rock bass online and it said that they are carnivorous... Are the fish in your system doing okay only eating the duckweed and snails from the tanks above?
Mar 26, 2011. 11:22 PMagatornz says:
looks great... i have a couple of white drums like that and was considering using them as they were with a lid on top - couple of questions;
-- dont quite get what you mean by having to cut a hole out of the fish tank to " allow oxidation" ?
--i am assuming only the bottom tank has fish in it>
-- what do you feed the fish>
cheers
Jun 7, 2010. 4:16 AMEmmettO says:
How many Rock Bass do you put in the lower tank? Do you start with more fingerlings and then thin them out as they get bigger?
Jun 2, 2010. 11:31 AMMoralito says:
 2 thumbs up!
Apr 15, 2010. 9:48 PMthebriguy says:
Really nice - thanks for sharing.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:fox45
