3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Building an electric racing car
Step 4The motor and drive system
The rules stipulate a 24 volt motor - the supplied motor is a wheel chair motor style without the attached slow speed gearbox. It operates at 20 amps at 2000 RPM.
With the gearing we have used it gives us a top speed at present of about 25 to 30 Mph - Not super fast but when your bum is only 2 inches from the ground!!
At a later date we will raise the gearing ratio slightly to up the top speed to 30 to 40 MPH provided we can do thig without over stressing the motor.
Cycle gears are also an option but may insert a complex system into something that needs reliability.
41 comments
1-40 of 41next »
Apr 24, 2008. 10:31 PMTheMadScientist says:
these motors can by aquired at your local flea market/ resale shop for sure! old and new air compressors alike love these things, and they tend to be pretty massive... also, backup generators use these in reverse to generate electricity, which means that they can be taken out and used as an electric motor aswell. a third source would be the obvious washing machine/drier but they're a bit more difficult to get loose...
Oct 16, 2011. 8:22 PMThe_Tom says:
I got a motor from an old treadmill is says its a
2.5 hp at 130 VDC
17.2 AMPS
7090 RPM
25C
Class B
Thermal switch: 120 VAC MAX. 1800 VA MAX
Im kind of unsure as to what most of these mean lol and would it be a good candidate for a small go kart like yours?
Oct 20, 2011. 8:56 AMomnibot says:
I'd say so. RPM looks a little high but gearing it down should take care of that. 2.5hp is a good amount of power for a small buggy.
Nov 8, 2011. 6:38 PMThe_Tom says:
im guessing it meant 2.5hp at 130 dc volts?
Aug 14, 2011. 5:01 AMtim127 says:
im trying to build an electric bike and the battary i want to use says its 10 ah and 24 volts how many amps is it and how well will it work with a 100 watt motor?
Aug 15, 2011. 5:27 AMtim127 says:
ok thank you, ill get a 250 watt moter and a better battary
May 28, 2008. 11:51 PMwee_man says:
Around how much did this cost and can you tell me what currency its in and also how much did the gokart weight with motor adn everything in execpt the driver cheers
May 29, 2008. 8:53 PMwee_man says:
thanks i was thinking of making something similar to the one you made 24v motor etc etc. but more in the style of a gokart. but weight will be a problem alwell and i was thinking of putting a lawn mower motor in the back with an generater running off it just incase i was a long away from home and ran out of battery
May 30, 2008. 1:29 PMwee_man says:
but with a lawn mower motor the spinning bit is horizontal whick would be a pain to use. You could use a chainsaw motor but then would it have enough power and speed required?
May 30, 2008. 8:22 PMwee_man says:
i would rather a go-kart feel but i would rather use a eletric motor because petrol costs so much now. but its cool how greenpower is interesting people in the use of eletricty but i reacon i more countrys their needs to be a contest like this
Nov 9, 2009. 9:23 PMDFree says:
What about using a car alternator on the wheel in the back that isn't attached to the motor. It would charge the battery while you drive. I don't know if it would put out enough power to keep the battery charged since its always running on electricity but it would certainly increase the amount of time you have.
Nov 13, 2009. 4:25 PMwee_man says:
(addingto joeofloath's comment)
The reason why no alternator is 100% efficient is because there is wasted energy.  In the motor (for say) 50w of energy is applied.  Some of that will be turned into heat and sound and finally the rest into kinetic energy.  Then theirs also friction with the tires on the ground. heat sound in the alternator too.
[quote]
When energy is transferred,
some of the energy turns into forms we don't want.
This energy is called wasted energy.
Wasted energy takes the form of heat and sometimes sound or light.
[/quote source http://www.gcsescience.com/pen20-energy-efficiency.htm]
Nov 13, 2009. 2:43 PMjoeofloath says:
It won't. No alternator is 100% efficient, so it will take (say) 50w to turn over, but only generate 10w. You can't generate power from no where anyway. You Use the battery power to move the car, slowing it down with an alternator is pointless.
Jun 2, 2009. 10:17 PMsnipe8 says:
you can make your go cart be faster by. putting the bigger gear on the motor and a smaller one on the wheel
Nov 9, 2009. 7:57 PMsnipe8 says:
lol. thats true
Aug 4, 2009. 4:56 PMkjjohn says:
is there an equation or something for figuring out how fast it will go with a certain gear ratio? I am designing an electric motorcycle and I would like to know.
Sep 14, 2009. 2:20 PMal9595 says:
only one wheel is moterized doesn't that mean it will go in circles?
Sep 20, 2009. 2:14 PMal9595 says:
ok i get it
Feb 12, 2009. 2:23 AMcarbon12 based says:
Hi, Did you do any calculations for the frame or just did a qualitative analysis. By looking at the pictures, you have the motor driving "one wheel" am I right? How does this impact the steering and handling? Would it steer to one side? If so, maybe getting some camber and toe in on the rear probably would fix that. You would loose some power due to the increased friction however that maybe worth it if you are constantly having to steer it back in a straight line. I know for simplicity reasons a Diff is not used and not enough power for a fixed 2 wheel (Drift action!). Great design wish i had this when I was in school, you must be like god to the students.
May 23, 2008. 3:47 PMmaxpower49 says:
how big is the moter not horse power but the dimensions
May 12, 2008. 3:11 AMskaltura says:
Look at brushless systems and LiPo. However the amps you are pushing are very far from even near the limits of NiMh. I haven't worked on this scale of systems, infact 1/10 scale cars, but on these, more power is being used than this on the top end. Older technology is limited on them to under 300watts however. But with modern technology, on sane bucks, you can already achieve 4kW and driving time of hours (as you very very rarely use even nearly the max). Under 1,000USD you can buy an 1/10 RC Electric Car with all you need, which easily outruns a nitro car, top speeds of over 100km/h, or around 65mph. And that's seriously scaled down stuff, weighting under 1kg total for the electrics, imagine 2-2.5kg RC car cruising at 65mph ;) You need scaled up for this, or either seriously short gearing (like 1:13 final drive), and preferrably multiple small motors, if you use what's found for RC cars. Look at Castle Creations, they are releasing new ESC, which can pull through continuously multiple kWs, and motors to go with it :) Also, those speaking of generators to use as motor --> Change the timing, it's all in the timing with brushed motors, however, no matter what kind of brushed motor, it's simply inefficient. Unfortunately, it seems you are restricted on the batteries & motor :( Fortunately, there's A LOT of things you can do besides these to increase overall efficiency and speed :)
Dec 28, 2007. 9:37 AMjakesllama says:
well i soppose it would be good for turning right... sweet video by the way did you enter the contest? i would love to build an electric car but i only have wood scraps... tah
Apr 24, 2008. 10:35 PMTheMadScientist says:
rick, may I ask if you know how to convert a belt drive type electric motor to a chain? the belt mechanism is seemingly friction welded to the shaft, but I have a strong dislike of belt drives...
Dec 28, 2007. 9:38 AMjakesllama says:
sorry i ment what contest did you enter?
Jan 16, 2008. 1:14 PMmaroadrunner says:
There is a similar contest in the United States. It is called Electrathon. People build electric cars and race them on 2x12v batteries over one hour. The goal is like above to go the farthest in that amount of time. As far as I can tell it is very similar as the best cars go 40 to 50 mph too.
1-40 of 41next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
82
Author:rickharris
Retired technology teacher - 2 kids, aged 62 I have an Hons deg in Design and Technology - 28 years as Computer systems engineer Trained as Electronics engineer in the Royal Air Force
