Step 5The motor control/electrical system
Although this system is very simple it is enough and reliable. Pulsing the switch on and off provided a crude speed control although for most of the race the motor is on if going in a straight line and off is the wheels are turned.
In line with the motor is a 70 amp thermal cut out to protect the motor from over current - I strongly recommend you fit this - the motor costs £100 new so protection seems advisable.
The motor runs at about 80 deg C in normal use but if stressed, e.g. pulling away from a slow spped too often, driving the motor when the wheels are turned, gearing up the drive too highly in the hope of attaining supersonic top speeds the motor temperature can ramp up alarmingly to the point of breakdown of the epoxy glue holding the windings in at about 200 deg C.
Some teams use water cooling as the motor is water proof, some like us use fins to provide air cooling.
The choice was made from calculations to acheive a top speed at 2000 of about 30 MPH - Actually we seem to ba about 28 MPH peak speed from road tests so the gearing needs to be raised slighthly - 1 or 2 teeth.
Many engineering suppliers will provide a range of gears which they sell to fit to electric motors. have a search in your area because any addresses I give you will be UK based and not a lot of use.
The greenpower site has a number of links to UK suppliers where you can get a feel for the type of product you need to be looking for.
Remember we are running very light! and get about 40 miles from our 2 batteries - If you load it up the range will drop dramatically (that's why ther e are, as yet, few dedicated electric cars on the road)
