3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Building the GEK Gasifier in seven parts
This project is part of a series of instructables from ALL Power Labs showing how to create a Honda Accord that runs on wood gas.
This project is entered in the Craftsman contest, if you like this project I hope you will consider voting for it. Just click the "Honda Accord" link above to go to the main project, then click the "Vote Now" button. Thanks!!  (note from after--- we won!  thank you to all who voted for us.  the shop is now much more full of tools thanks to sears)
This portion of the project shows fabrication instructions for the Open Source Gasifier Experimenter's Kit (GEK) from ALL Power Labs.
Note: The following fabrication instructions assume you already have cut out or otherwise acquired the necessary sheetmetal vessel tubes, flanges, plumbing parts and other accessories. If you have yet to do this, return to the main project Instructable and finish your prep work before continuing from here.
The GEK gasifier system consists of the following seven components. We will be building each of these components separately, the returning to the main project Instructable for final assembly and preparation to run.
Gas making:
1. Gas cowling and ash grate
2. Downdraft reactor
3. Fuel hopper
Particulate clean-up:
4. Cyclone
5. Packed bed filter
Gas combustion:
6. Centrifugal vac/blower
7. Swirl burner
CAD drawings for all the sheet metal parts and assembled vessels for how to build a GEK wood gasifer are in the main project Instructable, as well as on the download page of the main GEK site http://www.gekgasifier.com
Step 1Fabrication methods and standards
Fabrication Method and Standards
All GEK vessels are fabricated using the same three basic part types: vessel tubes, flange rings, and end plates. Flange rings and end plates are welded on the ends of the cylindrical vessel tubes. Flange rings are usually at the top of a vessel tube, and fit around the outside of the tube. End Plates are usually at the bottom of a vessel tube, and fit inside the tube.
In all vessels, the circular plates/rings function as the jigs to pull the vessel tubes to perfectly round for welding. Tabs and slots on all vessels simularly index the pieces together and ensure an accurate finished product. This system of self-jigging is central to the ease of building the GEK.
While following the step-by-step instructions that follow, be sure to remember these other common standards across the kit.
- All flange rings and end plates should be oriented such that the slag side is down. (note: Oct GEK run needs the reactor bottom plate flipped so slag side up. we made a mistake on this one)
- All vessel tubes are rolled such that the slag side is facing inward
- All vessel tube seams should be in the rear center of the vessel
- All large vessel tubes will have approximately 3/8" overlap at the seam joint. This makes welding much easier than welding sheet edge to edge. The smaller vessels (cyclone and swirl burner) will have 1/4" overlap at the seam
- Tabs and slots will give you the correct positioning. But do be careful to center the first tab and slot so the others will come out correct. See notes in below text for details.
- When welding flange rings and end plates, start with short stitches around the circle. Do not do one long continuous weld or you will warp the flange.
Once you've built all the components listed below, you can proceed on to Assembly Instructions for how to put them all together into a functioning unit.
13 comments
Jan 16, 2011. 6:16 PMjonathan_s says:
Just a FYI don't waste your time building a FEMA unit.... All you will do is end up with a bunch of head aches and stuck valves.....
Hi Jim found this page by checking my referral log on my web site......
Burn Baby Burn!!
Jonathan
www.woodgas.net
Jun 2, 2009. 10:51 AMducatidragon916 says:
could this be built separate and store the fuel and pump it into the car at a later time? In other words, could we build a mini plant at home use the fuel in the car in the storage tank instead of driving around with that bulky contraption in the back? Your thoughts..anyone?
Jul 28, 2010. 11:06 PMJuCo says:
there's a chemical process... or processes (not sure, not a chemist) that will turn the fuel into a diesel-type fuel. google "fischer-tropsch process for better info than i can offer.
Sep 27, 2009. 6:52 AMpaulo Bernardi Junior says:
I did not understand as if it makes the heating of the biomass gasificator, with coal? I will need mor information.
Sep 7, 2009. 8:49 AMsaadhaq says:
hi, really like the project, but i cant get a pro account, can anybody send the pdf steps to saad.ul.haq@hotmail.com
Jul 23, 2009. 11:09 AMANDY! says:
oh boy, this is very complicated. Could someone give me a very basic way of buildiing a small experimental GEK?
Jul 28, 2009. 6:54 PMANDY! says:
Sorta got a good idea for a small version now. Thanks!
Mar 22, 2009. 6:02 PMgjobjim says:
what motor was used for the vac blower, it also looks like it runs counterclockwise?
Mar 22, 2009. 10:10 AMmoris_zen says:
Didn't the gas companies get to you yet ? bribe you (kill you :-) ? I guess not .. it is still up . Good luck . don't remove even if they give you 5M$ . (I broke at 10M !)
Feb 28, 2009. 1:34 AMElectrix says:
How much would it cost for parts to build the gassafier, not the honda or any thing els
Jan 5, 2009. 1:08 PMDeusXMachina says:
That is absolutely AWESOME! Now I wish I had the welders and money to throw one of these suckers together. Good work.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
114
Author:jimmason
