3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Building the GEK Gasifier in seven parts
Step 22Downdraft reactor - 7
Install Nozzles
  • Weld 3/8 street elbows onto ends of 1" air nozzle tubes. Make sure the elbows are angled at 90 degree from the nozzle tubes
  • Screw in 1/2" X 6" pipe nipples into bottom of the reactor. Tighten modestly with pliers
  • Put clay gasket material around bottom of nipples, and a thin coating around the threads at the top of the nipples
  • Push the nozzles down over the nipples, into the clay. Take care to not get clay sealant into the nozzle tube passage.
  • Depending on your nozzle preference, and desired final height, you may want to install some spacers on the 1/2" nipple before pushing on nozzle tubes. In general, you should start with the nozzles at a height above the reduction cone, equal to the diameter of the reduction cone entrance.
  • The nozzles should point inwards towards the center of the reactor, and be firmly positioned in the clay. They should be difficult to turn.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
114
Author:jimmason
