Mongoose highlights:
- Powerful PIC18F2525 microcontroller (32KHz to 32MHz)
- Hardware PWM controlled SN754410 H-Bridge with thermal shutdown
- Differential drive with powerful 114.75:1 gearbox
- Low drag steel ball caster with steel rollers
- Dual optical rotation sensors (108 transitions per revolution)
- Dedicated in circuit programming / debugging connector
- Dedicated TTL Serial port (EUSART)
- Generous 400 hole solderless prototyping area
- Top mounted 20pin I/O for breadboard or LCD display
- Forward facing standoffs with 10pin I/O connector (0.1" PCB compatible)
- 10K trimpot and high brightness LED headlight (programmable)
- Very low center of gravity for stable operation
- Small enough to take anywhere 115mm x 110mm x 60mm
Programmable in ASM, Swordfish BASIC SE & C18 SE
Part 1: Chassis & Gearbox
Part 2: Electrical, motors & battery holders
Part 3: Electronics, 18F2525 Controller & SN754410 H-Bridge
Part 4: Final assembly, Main driving wheels, solderless breadboard
Part 5: Programming & Testing using Swordfish BASIC SE (free) & the Junebug (PICkit2)
Part 6: Demo code LCD, PWM and Tachometer examples
- Requires a PIC programmer, see the blueroomelectronics site for details.
Remove these ads by
Signing UpStep 1Preparing the Gearbox for the Dual Rotation Sensors
Simply remove by sanding or cutting away 5mm of material (plastic) from the main gearbox casing as shown in the illustration below.
The real fun begins with the programming, a free "Special Edition" of the Swordfish BASIC compiler for the PIC18Fxxxx microcontrollers is a great match for any robotics kit.
Swordfish BASIC
