3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Building the Mongoose Mechatronics Robot: Part 1 Chassis & Gearbox
This is the first of a series of illustrated instructions for assembling the Mongoose Robot kit available from blueroomelectronics
Mongoose highlights:
  • Powerful PIC18F2525 microcontroller (32KHz to 32MHz)
  • Hardware PWM controlled SN754410 H-Bridge with thermal shutdown
  • Differential drive with powerful 114.75:1 gearbox
  • Low drag steel ball caster with steel rollers
  • Dual optical rotation sensors (108 transitions per revolution)
  • Dedicated in circuit programming / debugging connector
  • Dedicated TTL Serial port (EUSART)
  • Generous 400 hole solderless prototyping area
  • Top mounted 20pin I/O for breadboard or LCD display
  • Forward facing standoffs with 10pin I/O connector (0.1" PCB compatible)
  • 10K trimpot and high brightness LED headlight (programmable)
  • Very low center of gravity for stable operation
  • Small enough to take anywhere 115mm x 110mm x 60mm
Requires 4x AA NiMH batteries
Programmable in ASM, Swordfish BASIC SE & C18 SE
Part 1: Chassis & Gearbox
Part 2: Electrical, motors & battery holders
Part 3: Electronics, 18F2525 Controller & SN754410 H-Bridge
Part 4: Final assembly, Main driving wheels, solderless breadboard
Part 5: Programming & Testing using Swordfish BASIC SE (free) & the Junebug (PICkit2)
Part 6: Demo code LCD, PWM and Tachometer examples
  • Requires a PIC programmer, see the blueroomelectronics site for details.
Step 1Preparing the Gearbox for the Dual Rotation Sensors
The Mongoose uses a Tamiya Double Gearbox. Part T4 requires a simple modification to allow the optical rotation sensors to monitor wheel rotation.
Simply remove by sanding or cutting away 5mm of material (plastic) from the main gearbox casing as shown in the illustration below.
10 comments
Apr 28, 2011. 2:33 PMxxlcamlxx says:
*Cough* Spam *Cough*
Jan 9, 2008. 6:21 AMKiteman says:
Not a wonderful Instructable anyway, as so much is missing, but this smells a little bit like cheap tinned meat.
Jan 9, 2008. 4:08 PMGorillazMiko says:
This is Part 1 of this Instructable as stated in the title.. it is not a WONDERFUL Instructable, but it is good. I can't wait to see all the parts! How many parts will there be?
Jan 10, 2008. 3:47 AMKiteman says:
I know it's "part one", but it also has phrases like "details asap" and "photos coming soon". It would have been much better to wait until the project was properly documented before it was posted, and I still smell the meat.
Jan 10, 2008. 4:29 PMGorillazMiko says:
True, this person should have finished everything. So basically it should be unpublished, but I cannot do that, and the pictures should be up soon, or things will get ugly. And I smell no meat.
Jan 11, 2008. 10:16 AMKiteman says:
Don't you? Sort of like tinned pork? Or tinned ham?
Jan 11, 2008. 3:46 PMGorillazMiko says:
Nope. :-)
May 28, 2008. 12:23 PM_soapy_ says:
I'd say this was spam, really, since it has been 5 months since it was posted, and the promised updates have not been forthcoming. Which is odd, because surely he will sell far more of them by increasing the quality of this Instructable?
Feb 2, 2008. 10:45 PMItsgoofytime says:
Bill is Legendary, so don't mess with him, he can jack you up. aka Krumlink
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:blueroomelectronics
