Step 2Adding the rotation encoders to two blue gears.
The kit includes a small piece of self adhesive aluminum foil with a hole punched in the center.
You will need two of the blue gears as supplied with the kit.
- Cut the foil into four pieces using the hole as the center.
- Remove the adhesive backing from the foil only when you're ready to apply it
- Apply two foil pieces to each gear, each foil piece should be opposite each other.
- Carefully burnish the foil onto the gear with a toothpick or soft burnishing tool (the example below use a piece of spruce from the gearbox assembly)
- Carefully trim away excess foul by slowly running a sharp hobby knife through the foil as show in the pictures below.
Add Comment
