Step 6Wiring up the controller
I'm running the power for my controller off the power supply for my media pc. The power supply is rated for 20A on the 5V line, but this system requires around 12A. The controller is not capable of powering off usb unless you are doing under 500ma total and this is way beyond that.
191 led's * 3 colors * 20ma = 11460ma. 11460 = 11.45A, plus a bit for the controller.
I initially powered this off my 550w power supply in my pc but with this on my 5v line drops to 4.85v from it's normal 4.98v and my usb devices start to act very sketchy. I grabbed a spare 400 watt very cheap no-name power supply which I had sitting around and it died after running this for 15 minutes. I recommend a decent brand which is separate from your computer.
If you want to use an external power supply, you can connect the green wire in the motherboard connector to a ground (any black) to power it on without a pc. You can find more details here or on google.
An additional info you could provide on wiring an external power supply would be much appreciated.
http://www.instructables.com/id/LED-RGB-controller/
http://groovygamegear.com/PDF/LEDWIZ_INSTALL.pdf
The LED wiz is expecting the cathode to go to the ports, so if you use those LED's you won't be able to control each color properly I don't think.
Once you factor in the price of buying the transistors and making the circuit more complicated you might want to just forget it and get the other LED's. *shrug*
http://www.newegg.com/Product/Product.aspx?Item=N82E16817170018
This is a super cheap one and a non-name brand, but it lists under the specs +5V@36A. This is totally overkill so if the power supply is capable of putting out anywhere near that much in reality, it should work fine. All you need is around 15A. Your current PC power supply might be enough as it is.
Would I be able to use this reliably without the 5V line dropping significantly and causing problems as you mentioned?
