Bullet Bracelet
4,461
53
6
Published
Introduction: Bullet Bracelet
About: Love to try and win Instructable contests!
Ever wondered what you could do with empty bullet shells? This is an instructable showing you how to create an awesome, bendable, unisex bracelet. You'll need:
- 2 empty bullet shells
- Shoelace or Paracord (any hollow cord that can be threaded)
- Wire (any bendable kind but not to thick)
- Craft or Super Glue
- Scissors
- Pliers
Step 1: Cutting
Firstly, cut your shoelace or paracord at your desired length using a pair of scissors. If you want a tight bracelet/band measure it around your wrist. Now cut the wire the same length as the lace using pliers.
Step 2: Threading
This is the most difficult and fiddly part of the task. Lightly pinch open your shoelace/paracord and thread your wire whether it be a pipe cleaner or coat hanger through.
Step 3: Glueing
Finally, squirt some glue into the empty bullet shell and then place it over your bracelet. Repeat this on the other end. Leave your work to dry.
Step 4: Done!
Your band/bracelet is complete! You can now shape/bend it around your wrist or ankle. Wear it around and experiment with other materials!
    • Pets Challenge
      Pets Challenge
    • Stick It! Contest
      Stick It! Contest
    6 Comments
    The magnets are a great idea! if you slip one into the bullet on each side it will close nicely. I suggest a strong earth magnet.
    aloha! I Love the idea! a great tip I recommend is to stick a small magnet into one of the shells before doing the following steps.
    The "shell case" is brass and thus non-magnetic.
    how about a magnet in each side? i bought a cheap bracelet [$1] with a magnet hidden in each end, just for the ends! thought i could re-tool it, but it's trickier than i realized (complicated connectors).
    Thanks! Yous saved me a couple of dollars! I was just about to go buy some powerful magnets when I saw your comment! Thanks again!
    Wow awesome idea! I might buy a magnet and try it! Ill give you an update if I do!
