Bullet Cartridge USB Drive by moengineer
Featured
Step 2: Starting Construction
1)  With a tube cutter cut the top and bottom off both cartridges.  I'm using a Plumbers tube cutter.  I left as much body on the cartridge as I could so I can adjust later.
2)  Use a thick piece of steel and an angle grinder to but a jig the same size as a USB.  This is sort of a guess and check.  I used a sharpie and a caliper to get close.  Also chamfer the top edges so you can get the brass started.  Be sure to make each chamfer identical otherwise you risk stretching out or tearing one side.
3)  Stretch the cartridge over the jig gently with a hammer.  I used several very light strokes to guide the brass onto the jig.
4)  Follow point 2, grind a second Jig that fits the smaller rifle cartridge.
5)  Stretch the larger cartridge gently over the new jig just like in point 3.
6)  See how they fit.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
