3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Bullet Shell Pan Flute
Step 2Attach a Bullet
Attach a Bullet
This is the part that takes some patience and a touch of dexterity. If you need to cheat use super glue and then come back later. Even without the super glue though the wire will be plenty to hold them in place (I didn't use glue).
First cut a length of wire about 20-30 inches long (eyeball it). Then place your bullet casing against your rod and start looping the wire around both pieces in a crisscross pattern. If you are going for the 'rough' look like mine then don't worry about being perfect. Once you have enough loops around it twist the two ends together like a twist tie on a loaf of bread. If you want you can use wire cutters to snip off the extra, I left mine on trying to get a barbed wire look.
Go down the entire rod adding all of your casings. Make sure you leave enough room between them, too close together and you will be hitting two notes at once when you play. I found about 1/2 an inch was plenty, or about the width of another casing.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:rabidiga(Guns, Girls and Gadgets!)
I love making things just to prove that I could.
