3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Bullet Shell Pan Flute
Step 3Bottom Row
Bottom Row
Now that your top row is all attached you need to add the bottom row
"But Iga, WHY do we need a bottom row? They are all held in place already.."
Good question! If you only have 1 rod the bullets casings are going to swivel freely around the rod, making it so that you can't blow evenly across them all. The second rod puts them all evenly up and down.
Now when attaching the bottom rod you will use the same technique as the first. But make sure to attach the two outer casings first, this will lock in the rod and make it worlds easier to attach all the middle bullets.
Once they are all tied on you can now tweak each bullet moving them up and down until they are relatively strait along the tops. This makes it easier to find the holes as you play, they don't have to be perfect but as long as they aren't all over the place it will work fine.
Tip 1- Now you can add a dab of superglue down between the casing and the rod. This will help keep them from moving around on you later. They do slide up and down still and could potentially fall out if you drop it.
Tip 2- I suppose if you really want you could fine tune the sounds by dropping tiny amounts of craft glue into the bullets. Try not to hit the wall of the casing, you want it to pool at the bottom. This in effect makes the chamber of the casing shorter, giving it a higher pitch. It's like a soda bottle, the more liquid you have in it the higher the note.
Congratulations, you now have a ballistic pan flute!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:rabidiga(Guns, Girls and Gadgets!)
I love making things just to prove that I could.
