Introduction: Bullet Shell Screwdriver
For this simple instructable, I take an empty bullet shell an turn it until a very useful pocket tool.
Step 1: Supplies
The first thing you're going to need to do is gather you supplies. You will need epoxy, an empty bullet shell, a philips head screw driver drill bit.
Step 2: Mix the Epoxy
Mix the epoxy with a Q-tip. Make sure you don't let it touch your hands and open a window. This stuff is like smelly super glue.
Step 3: Inserting the Drill Bit
Rub the epoxy all over the part of the drill bit that would usually be inside the drill. Place the drill bit inside the empty shell with the screw driver part sticking out, It should fit snugly.
Step 4: Finished!
Now you're finished!!! Be sure to allow 24 hours for the epoxy to cure.
Finalist in the
Pocket Sized Contest
Redneck Contest
