Bullet Shell Valve Stem Caps
Introduction: Bullet Shell Valve Stem Caps
The inner diameter of a 40 cal. bullet shell happens to fit nicely over a valve stem cap. All you have to do tap the shell onto the cap with a hammer. These went to the same friend who got the retractable bullet pen.
Safety first: The shells were already expended by the time I got them. Never attempt to use a live round for any kind of project. Serious injury or death can occur.
  • Pocket-Sized Contest
  • Pro Tips Challenge
    Pro Tips Challenge
  • Science of Cooking
    Science of Cooking
I have seen them using Dice instead and lots of colors to choose from.
all I have to say is I'm just mad that I did not think of it my self props to you
THIS IS AWESOME!!! me and my frkiends ride BMXs, and the ultimate coolness s to have the little bullet shaped valvecap, that you can get from the store -for $10. however, not only would these look cooler, but ièm sure they would be cheaper. can i just ask, where do you get the bullet shell casings from
it looks nice, but be aware that the shells are quite heavy so don't forget to balance (is this the proper word?) the wheels at tire mechanics. Otherwise you are shortening the life of your wheel bearings.
Not trying to cut you down or anything, but empty shells are really quite light. I would say this probably does little more than triple the tiny weight of the cap. This still may need a re-balance I'm not sure about that.
well, the balancing is always done with cap on the wheel. even if the tire is partially wet (slowly went with dry tire through small water pool on the road) the measurement will be affected.
try to weight that empty shell, I'm sure it's more than several grams and the weights for balancing are stepped by 5 grams.
I had no idea wheel weights were stepped by such a small amount. I doubt I'l ever get my hands on a casing.
well, driving 50 km/h makes your 16" wheel rotate 662 times per minute.
50 km/h divided by 60 minutes is approx 833 m / min divided by the length of 16" (40cm) wheel is 833 m / (0,40 m * 3.1415) is 833 m / 1,2566 m is about 662 rotations per minute. http://www.google.sk/search?q=(50000+%2F+60+)+%2F+(16+inch+*+PI)
Driving at highway's allowed 130 km/h makes nearly 1700rpm. http://www.google.sk/search?q=(130000+%2F+60+)+%2F+(16+inch+*+PI)
Attach 20cm ribbon to an 10g screw and try to rotate it at approx 5 rpm in your hand (which is pretty fast) to get the feeling about the power of centrifugal force. And now imagine the power of centrifugal force that is applied to axis of the wheel by every nonbalanced gram of weight at highway speed.
all due respect I have over 1500 rounds of 40 cal in my garage and and know full well that a piece of gravel stuck in the tire would do more to un-balance a tire then a piece of brass or nickel that ways less then 1/4 of an ounce. I mount and balance my own tires to I don't use wheel weights I use plastic beads for airsoft guns 7oz for 33" tires and 1oz to every inch you add to the diameter. I have even ran tires with no weights and the arent effected by anything less then about 3 ounces out of balance. I have had tires (big ones 37") that were 12 ounces out of balance. They ran perfect with 10 ounces of beeds in the tires. even small radials weigh in at 60-70 lbs of rubber/steel or aluminum/ and air. 1/4 ounce won't make a difference and no the tires are not balanced with the valve cap on. Infact in most cases your lucky if you get the same ones back from the tire store since they have thousands laying around on the floor.
