Bulli Pumpkin
295
12
4
Published
Introduction: Bulli Pumpkin
Hi
I want to show you how to make a Bulli pumpkin.
Bulli is a popular name for VW T1 - the coolest mini van in a history, produced between 1950 - 1967.
if you look at the front of the car you can see very nice "face" which is great inspiration for a Halloween pumpkin!
Step 1: Preparation
To make a Bulli pumpkin you need:
- nice round pumpkin
- a snap-off knife
- small kitchen knife
- round object ( it can be wire, file, screwdriver or so)
- a spoon
Of course it would be much easier to use a Dremel tools, but it is also a lot of fun doing it only with very simple hand tools!
Step 2: Shaping
First you have to draw a shape off all elements that will be cut. The best is to use pencil or ball pen - that leaves gentle and light lines, because at the very end you have to remove them. You can use marker but it i very hard to remove.
After all elements are drown, you can start with making holes in all the corners - it will help a lot in cutting out the windows.
Then with snap-off blade connect appropriate holes. BE CAREFUL - pumpkin is hard and when you push too hardly you can go too far or even hurt yourself.! It is better to make a few smaller cuts than one deep.
Headlights it is easier to make with small kitchen knife, just by rotating it.
Step 3: Make It Empty
Now use the spoon to remove pumpkin's guts :)
You have to be very patient and gentle so window frames are not destroyed.
Step 4: Final Touch
With snap-off knife remove pumpkin's skin from the upper part of the "car"
Step 5: The Light
The last step is to put any kind of light inside the Bulli!
As the top is not removable it is best to drop inside battery with a small LED. It is also safer than a candle!
Enjoy!
    • Stick It! Contest
      Stick It! Contest
    • Pets Challenge
      Pets Challenge
    4 Comments
    true beauty
    Fun. I think that this is actually the first car jack o lantern that I have seen.
