Bullnose LED Bike Light and Dynamo USB Charger
 by hydronics
Contest Winner
 This bike has a dynamo front hub that is wired to LED lights.  In addition there is a power output via a female USB plug.  You can charge your phone, ipod, GPS or any USB powered device.
In this design, the USB charging station can be unplugged when not in use. When charging the devices can be kept in your pocket or backpack.
The charging station has four AAA rechargeable batteries wired parallel to the female USB that provide a secondary energy storage and once charged can power a USB device independent from the bike.
You can use the dynamo to power the lights or the USB but not simultaneously.  A toggle switch on the bullnose handlebars turns the front lights off.
Step 1: Circuits
 There are quite a few circuits and great LED tutorials on Instructables. Just check out some resources to get your bearings.
LED for beginners: www.instructables.com/id/LEDs-for-Beginners/
try out different circuits... blinking, back light, combinations =>
pilom.com/BicycleElectronics/DynamoCircuits.htm
As the front wheel turns it creates alternating current (AC) power.  The 'bridge' is a rectifier that converts the AC dynamo power to DC power. The bridge is made up of qty(4) 1N5818 diodes.
Bike Light Encapsulated in Epoxy
The battery pack absorbs any power not consumed by the USB device.
Parts:
qty(4) 1N5818 Diodes
qty(8) White LEDs
qty(1) Battery Pack
panigrc says: Oct 12, 2012. 1:57 AM
Dear hydronics,
at first I want to congratulate you for this very usable instructable.
Because I want to built it I have some questions.
I don't know much about electronics but I've searched a lot until I found your instructable and I've seen lots of designs.
I am looking for ways to improve your circuit so here are my questions:
1) Why do you have the second pair of LEDs in series and not in parallel?
2) Why do you use a resistor ?
3) Why don't you use a capacitor (I 've read here http://www.pilom.com/BicycleElectronics/DynamoCircuits.htm) that using a capacitor improves the lighting and decreases flickering
4) Is it possible to have the batteries connected always with the LEDs so even if the dynamo isn't working the LEDs would remain ON.
I would be glad if you (or someone) could answer my questions.
Thank you in advance :)
ohthatshowitworks says: Jul 30, 2012. 2:30 PM
ACE!
Where would i Put an LDR in addition to the switch?
Excuse the Newbe question.
porkypinekiwi says: Aug 1, 2010. 8:27 PM
about the hub is it easy to connect the spokes onto it?
siggivara says: May 5, 2010. 10:37 AM
Exelent stuff.
Does this react/protect against overcharging? I'm a little worried about excess power frying whatever device I'm charging.
hydronics (author) in reply to siggivaraMay 6, 2010. 1:04 AM
 the battery pack absorbs excess energy while peddling... I suppose it does the same thing once the device is charged... start cheap, go big, good luck. -tom
peteoc says: Apr 5, 2010. 6:07 AM
this isn't wanting to charge my iphone 3gs, any ideas? I've taken a photo of my breadboad setup.
I'm powering this using a 6V DC adapter for testing purposes.
peteoc in reply to peteocApr 6, 2010. 3:58 AM
I've been researching this more and it appears iPhones require reference charges on pins 2 & 3.
On pin 2 it requires 2.5v and 3 requires 1.8v - It appears these reference voltages are only required to tell the phone to start charging, once the phone has started charging these voltages can be removed.
I'm going to sort out my setup first and will post a more detailed instructable.
hydronics (author) in reply to peteocApr 5, 2010. 8:57 PM
 yea... it should work...your board looks good.
couple things to check of course.
-the led should be unplugged for usb charging
-maybe check you got the voltage at the USB pins
-finally the diodes are supposed to convert from AC to DC (the dynamo produced AC current)  you indicated you have a DC source and the DC should pass through the diodes. It obviously passes through to light the LED, eh?
let me know when you figure it out.
peteoc in reply to peteocApr 5, 2010. 6:09 AM
a better quality image can be found at http://oc22.co.uk/DSC_0010.jpg
siggivara in reply to peteocMay 5, 2010. 10:39 AM
(removed by author or community request)
siggivara in reply to siggivaraMay 5, 2010. 5:23 PM
IPod and iPhone need a "signal" so they know it is OK to charge, they need about 2.7 Volts on D- and 2 Volts on D+
You could modify the charger to make it work with iPod/iPhone by following this schematic:
http://img39.imageshack.us/img39/9928/f17v2ncfkhqcshjmedium.jpg
That should make it work with your iPhone/iPod.
peteoc says: Mar 31, 2010. 9:33 AM
Sorry to drag up the past however I'm looking at a possible solution to charge my iphone while out on long hauls. I assume it's possible to simply drop the LEDs from the circuit diagram and go forward with just the USB section?
hydronics (author) in reply to peteocApr 4, 2010. 12:57 AM
 yep,
let me know if you have any questions. look at the circuit diagrams, follow the links, etc... as we say in Portland, "do it better"
Have fun.
DaveG20 says: Jan 23, 2010. 3:11 PM
Hi there, great idea! how long does it take you to charge your 4 AA batteries while riding at a normal pace?
hydronics (author) in reply to DaveG20Jan 23, 2010. 4:53 PM
 i'v no idea. The battery pack is used as a buffer when running my ipod. It absorbs the excess electricity generated by the hub but not used by the ipod.  I don't use the battery pack as a standalone device... although you could!
hydronics (author) says: Nov 5, 2009. 9:22 AM
yea, as soon as I finished I wanted rear lights too.  I'll have to hack those in shortly. The nights are getting longer.
henkmans says: Nov 5, 2009. 6:36 AM
 What a super cool idea! I thought of it too, except for the fact that I have a ramshorn steer
tevers94 says: Nov 4, 2009. 2:33 PM
Thats a pretty cool idea.  I might try that except for rear lights.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
