Bumble Bee Crochet Snuggle Snack
Published
Introduction: Bumble Bee Crochet Snuggle Snack
About: Encompassing well-known brands Patons, Bernat, Caron, and Lily Sugar 'n Cream, Yarnspirations.com is a one-stop resource for everything that you need to create knit and crochet projects to suit any mood, bud...
Kids are buzzing about our new Bumble Bee Snuggle Sack! Crocheted using Bernat Blanket and Blanket Brights, this sweet-as-honey project will be a hit at the next sleepover.
View all patterns: http://bit.ly/2bAckDr
View all yarn: http://bit.ly/2bhO1dB
Step 1: Supplies, Measurements and Abbreviations
MEASUREMENTS
Approx 52" circumference, excluding wings x 60" long.
GAUGES
7 sc and 8 rows = 4" with larger hook. 10 sc and 10 rows = 4" with smaller hook.
Supplies and Tools
· Bernat® Blanket Brights™ (10.5 oz/300 g; 220 yds/201 m)
· 3 balls Contrast A School Bus Yellow or 560 yds/512 m
· Bernat® Blanket™ (10.5 oz/300 g; 220 yds/201 m)
· 3 balls Contrast B Coal or 625 yds/572 m
· Bernat® Blanket™ (5.3 oz/150 g; 108 yds/98 m)
· 1 ball Contrast C Vintage White or 49 yds/43 m
· Sizes U.S. K/10½ (6.5 mm) and U.S. L/11 (8 mm) crochet hook or size needed to obtain gauge.
Abbreviations
Approx = Approximate(ly) Beg = Begin(ning) Ch = Chain(s) Cont = Continue(ity) Dc = Double crochet Hdc = Half double crochet Rem = Remaining Rep = Repeat Rnd(s) = Round(s) Sc = Single crochet Sc2tog = Draw up a loop in each of next 2 stitches. Yoh and draw through all loops on hook. Sl st = Slip stitch St(s) = Stitch(es) Tog = Together Yoh = Yarn over hook
Step 2: Bumblebee Body
BODY
· First ring: With larger hook and B, ch 2.
· Rnd 1: 4 sc in 2nd ch from hook. Join with sl st to first sc.
· Rnds 2 and 3: Ch 1. 1 sc in each sc around. Join with sl st to first sc.
· Rnd 4: Ch 1. 1 sc in first sc. 2 sc in next sc. 1 sc in next sc. 2 sc in next sc. Join with sl st to first sc. Join with sl st to first sc. 6 sc.
· Rnd 5: Ch 1. 2 sc in first sc. 1 sc in next sc. *2 sc in next sc. 1 sc in next sc. Rep from * around. Join with sl st to first sc. 9 sc.
· Rnd 6: Ch 1. 2 sc in each sc around. Join with sl st to first sc. 18 sc.
· Rnds 7 and 8: Ch 1. 2 sc in first sc. 1 sc in each of next 2 sc. *2 sc in next sc. 1 sc in each of next 2 sc. Rep from * around. Join with sl st to first sc. 32 sc.
· Rnd 9: Ch 1. 2 sc in first sc. 1 sc in each of next 3 sc. *2 sc in next sc. 1 sc in each of next 3 sc. Rep from * around. Join with sl st to first sc. 40 sc.
· Rnd 10: Ch 1. 2 sc in first sc. 1 sc in each of next 4 sc. *2 sc in next sc. 1 sc in each of next 4 sc. Rep from * around. Join with sl st to first sc. 48 sc.
· Rnd 11: Ch 1. 2 sc in first sc. 1 sc in each of next 5 sc. *2 sc in next sc. 1 sc in each of next 5 sc. Rep from * around. Join with sl st to first sc. 56 sc.
· Rnd 12: Ch 1. 2 sc in first sc. 1 scin each of next 6 sc. * 2 sc in next sc. 1 sc in each of next 6 sc. Rep from * around. Join with sl st to first sc. 64 sc. Cont even in sc until work from beg measures 12".
· Next rnd: Ch 1. *Sc2tog. 1 sc in each of next 2 sc. Rep from * around. 48 sc. Break B. Join A.
· Second ring: Next rnd: With A, ch 1. 2 sc in first sc. 1 sc in each of next 2 sc. *2 sc in next sc. 1 sc in each of next 2 sc. Rep from * around. 64 sc.
· Next rnd: Ch 1. 2 sc in first sc. 1 sc in each of next 7 sc. *2 sc in next sc. 1 sc in each of next 7 sc. Rep from * around. Join with sl st to first sc. 72 sc.
· Next rnd: Ch 1. 2 sc in first sc. 1 sc in each of next 8 sc. *2 sc in next sc. 1 sc in each of next 8 sc. Rep from * around. Join with sl st to first sc. 80 sc. Cont even in sc until work from last color change measures 12".
· Next rnd: Ch 1. *Sc2tog. 1 sc in each of next 2 sc. Rep from * around. 60 sc. Break A. Join B.
· Third ring: Next rnd: With B, ch 1. 2 sc in first sc. 1 sc in each of next 2 sc. *2 sc in next sc. 1 sc in each of next 2 sc. Rep from * around. 80 sc.
· Next rnd: Ch 1. 2 sc in first sc. 1 sc in each of next 9 sc. *2 sc in next sc. 1 sc in each of next 9 sc. Rep from * around. Join with sl st to first sc. 88 sc.
· Next rnd: Ch 1. 2 sc in first sc. 1 sc in each of next 10 sc. *2 sc in next sc. 1 sc in each of next 10 sc. Rep from * around. Join with sl st to first sc. 96 sc.
· Next rnd: Ch 1. 2 sc in first sc. 1 sc in each of next 11 sc. *2 sc in next sc. 1 sc in each of next 11 sc. Rep from * around. Join with sl st to first sc. 104 sc. Cont even in sc until work from last color change measures 12".
· Next rnd: Ch 1. Beg with first sc. *Sc2tog. 1 sc in each of next 2 sc. Rep from * around. 78 sc. Break B. Join A.
· Fourth ring: **Next rnd: With A, ch 1. 2 sc in first sc. 1 sc in each of next 2 sc. *2 sc in next sc. 1 sc in each of next 2 sc. Rep from * around. 104 sc.
· Next rnd: Ch 1. 2 sc in first sc. 1 sc in each of next 12 sc. *2 sc in next sc. 1 sc in each of next 12 sc. Rep from * around. 112 sc. Cont even in sc until work from last color change measures 12".
· Next rnd: Ch 1. *Sc2tog. 1 sc in each of next 12 sc. Rep from * around. 104 sc.**
· Next rnd: Ch 1. *Sc2tog. 1 sc in each of next 2 sc. Rep from * around. 78 sc. Break A. Join B.
· Fifth ring: Rep from ** to ** as given for Fourth ring, substituting B for A. Fasten off.
Step 3: Small Wings
Small Wings (make 2)
***With smaller hook and C, ch 10.
· Rnd 1: 1 sc in 2nd ch from hook. 1 sc in each of next 2 ch. 1 hdc in each of next 3 ch. 1 dc in each of next 2 ch. 7 dc in last ch. Working across opposite side of foundation
· chain, 1 dc in each of next 2 ch. 1 hdc in each of next 3 ch. 1 sc in each of next 2 ch. 2 sc in last ch. Join with sl st to first sc.
· Rnd 2: Ch 1. 1 sc in each of first 3 sc. 1 hdc in each of next 3 hdc. 1 dc in each of next 3 dc. (3 dc in next dc. 1 dc in next dc) 3 times. 1 dc in each of next 2 dc. 1 hdc in
· each of next 3 hdc. 1 sc in each of next 3 sc. 3 sc in last sc. Join with sl st to first sc.
· Rnd 3: Ch 1. 1 sc in each of first 3 sc. 1 hdc in each of next 3 hdc. 1 dc in each of next 4 dc. (3 dc in next dc. 1 dc in next dc) 5 times. 1 dc in each of next 3 dc. 1 hdc in each of next 3 hdc. 1 sc in each of next 3 sc. 2 sc in next sc. 3 sc in next sc. 2 sc in next sc. Join with sl st to first sc.
· Rnd 4: Ch 1. 1 sc in each of next 3 sc. 1 hdc in each of next 3 hdc. 1 dc in each of next 5 dc. (3 dc in next dc. 1 dc in each of next 3 dc) 5 times. 1 dc in each of next 2 dc.
· 1 hdc in each of next 3 hdc. 1 sc in each of next 3 sc. (2 sc in next sc. 1 sc in next sc) 3 times. 2 sc in last sc. *** Join A with sl st to first sc.
· Rnd 5: With A, ch 1. 1 sc in each of first 4 sts. 2 sc in next st. 1 sc ineach of next 5 sts. 2 sc in next st. Rep from * to last st. 1 sc in last st. Join with sl st to first sc. Fasten off.
Step 4: Large Wings
Large Wings (make 2)
Work from *** to *** as given for Small Wings. Join with sl st to first sc.
· Rnd 5: Ch 1. 1 sc in each of first 3 sc. 1 hdc in each of next 3 hdc. 1 dc in each of next 6 dc. (3 dc in next dc. 1 dc in each of next 5 dc) 5 times. 1 dc in next dc. 1 hdc in each of next 3 hdc. 1 sc in each of next 4 sc. (2 sc in next sc. 1 sc in next sc twice. 1 sc in each of next 2 sc. (2 sc in next sc. 1 sc in next sc twice. Join with sl st to first sc.
· Rnd 6: Ch 1. 1 sc in each of first 3 sc. 1 hdc in each of next 3 hdc. 1 dc in each of next 7 dc. (3 dc in next dc. 1 dc in each of next 7 dc) 5 times. 1 hdc in each of next 3 hdc. 1 sc in each of next 5 sts. (2 sc in next sc. 1 sc in each of next 2 sc) twice. 1 sc in next sc. (2 sc in next sc. 1 sc in each of next 2 sc) twice. Join A with sl st to first sc.
· Rnd 7: With A, ch 1. 1 sc in each of first 4 sts. 2 sc in next st. *1 sc in each of next 7 sts. 2 sc in next st. Rep from * to last 2 sts. 1 sc in each of last 2 sts. Join with sl st to
· first sc. Fasten off.
FINISHING
Sew Wings to Body as seen in
picture.
    • Spotless Contest
      Spotless Contest
    • Slow Cooker Challenge
    2 Comments
