My son ran through the house, placed the torch here and there and said ".. this is a trap for burglars .." by letting the torch send a light stream across the room.
This made me think of a photo sensor to build a "real trap for burglars".
Remove these ads by
Signing UpStep 1Planning
- easy to use for my son
- powered by battery
- work with minimum power consumption
- audible alarm
- don't buy anything! Everything should by surplus material
I searched around an found an old photo sensitive transistor mounted on a pice of plasic together with a small resistor. The transistor had BPY 62 III written on it.
First I thought of building a schmitt trigger using an op amp. Then I saw in one of my old electronic books a principle circuit diagram of a shmitt trigger build with transistor.
I decided to use a 9V block cell battery as a power source. For the audible alarm I used an piezo electirc signal generator. The schnitt trigger needs a current of about 11 mA to flow through the collector. The piezo electric element does not generate this much current. To make the circuit work I put an led in parallel to the piezo. This way I got a visible alarming to.
14
comments
Add Comment
Yerboogieman
says:
Yerboogieman
says:
frickelkram (author)
says:
says:
zachninme
says:
says:
Add Comment
