Introduction: Burlap Sunflower Pick
About: I love to make and share crafts.
I wanted to make my own sun flower pick for fall wreaths. You can make any color you like. I hope you have fun making this flower.
Step 1: Material You Will Need
15" of 5 1/2 wide burlap - color of your flower
5" of 5 1/2 wide burlap - green for your leaves
Scrap piece of brown burlap for the center
Cutting mat
Decoupage
wide sponge brush
1 fine gauge wire
Scissors
Flower template mine came from http://www.freekidscrafts.com
I could not find a leaf template so I have included a picture of what I free hand cut
2 paper plates
one plastic rectangular bowl
Straight pins with the heads on them
Step 2: Step 2: Decoupage
Pour about a half of a cup of your decoupage into the plastic bowl.
then pour enough water into the decoupage to make it thin. You will know it is thin enough when it drips off your brush.
Use your first paper plate and lay your burlap piece down and start brushing until you have covered the whole piece.
Place the piece on the clean paper plate and repeat. I did take another plate for the 6" of the green burlap.
I let mine dry over night.
Step 3: Step 3: Pin and Cut Flowers Out
You will need to cut your flower templates out. I down loaded the flowers and then resized them to 5", 4", and 3".
Take your straight pins, I use the ones with the heads on them, and pin from the top of the peddles to the center.
Now a trick I use is to start with a peddle and cut around the top then do the same thing with each peddle until you have gone all the way around. I then turn over the peddle and cut the opposite side of each peddle. Look at the picture of the front and back of the peddles and you will see this gives you a clean cut.
Now take your pins out and you will be ready to assemble.
Step 4: Step 4: Putting Your Flower Together
In the first picture you will see I am using my fingers to fold the flower in haft, I will do this on both sides of the flower to find the center.
Now stack each of your flowers and turn over to slide the wire through the center. If you do not want to use the flower for a pick skip this step and glue each one in the center.
Turn over and glue your center circle of brown burlap in the center.
Turn back over and lay your leaves, you can use as many or little as you like, to the back of the flower.
Glue the leaves on.
That is it and now you have your burlap flower as a pick or you can make and use on hats, headband, anything you like. Hope you enjoyed this.
Please let me know if you have any question.
