Using a candle, and a tube, you can burn candle smoke.
FIRE IS DANGEROUS If you do not know this, you should not attempt this instructable, or any like it.
Step 2: Set up
Place the tube over the lit candle. You want to get the bottom end of the tube close enough to the wick to produce a stream of white smoke out of the top end of the tube. Too close to the wick, and the candle will go out, too far from the wick, and the stream of smoke will not be thick enough.  You may have to try different types of tubes and placing the tube at different angles.
Step 3: A little bit of candle science
The white smoke coming out of the top of the tube is condensed wax vapor. A burning candle is a bit more complicated than you might think. If you think about it too much, it might drive you mad. Here is the short version....The burning wick melts the wax. The wax gets wicked up the wick. The wax vaporizes. The wax vapor (combined with oxygen and other chemicals in the surrounding air) burns. You will be splitting this vapor, so it will burn at two places.
Step 4: Lite the smoke
Once you have your stream of white condensed wax vapor, you are ready to lite it. Start with the lighter about two inches above the top of the tube. Notice how the stream of smoke does not continue above the flame of the lighter. Move the lighter lower until the flame connects to the top of the tube.
Step 5: Enjoy
As with all instructables, enjoy. Sit back and let your mind wonder. See how hot the tube gets. Play with the setup. See how big you can make the top flame. Get as many candles with as many tubes all focused into one giant top flame. Do something artistic. If you want to share your creation, send comments with photos or make your own instructable. I would love to see what this inspires.
Thanks for reading.
sunshiine says: Nov 4, 2011. 4:36 AM
Oh yeah I voted!
CHARLESCRANFORD (author) in reply to sunshiineNov 5, 2011. 6:58 PM
Thanks.
sunshiine says: Oct 22, 2011. 1:33 PM
Kewl! I wonder if this could be considered a steam punk candle. To me it looks the part. Thanks for sharing!
Sunshiine
CHARLESCRANFORD (author) in reply to sunshiineNov 4, 2011. 4:00 AM
Probably. I am thinking of making something along the same idea, just permanent and a bit more elaborate. Once I come up with something, there will be an instructable.
sunshiine in reply to CHARLESCRANFORDNov 4, 2011. 4:35 AM
Thanks for sharing! Have a beautiful fall day!
sunshiine
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
