loading
loading
Picture of Burn candle smoke
Using a candle, and a tube, you can burn candle smoke.
FIRE IS DANGEROUS If you do not know this, you should not attempt this instructable, or any like it.
Step 1: Materials
Picture of Materials
To perform this experiment you will need the following items:
1. a candle (any type will do)
2. a tube (I used a 1/4"O.D. 5 32" I.D. copper tube like the one used on http://www.instructables.com/id/BUTTONHOLE-PUZZLE-POCKET-SIZED/) you could also use aluminum, brass, steel, and even glass.
3. a lighter or match
4. Something to hold the tube, it gets hot. (I used a helping hand tool)
Step 2: Set up
Picture of Set up
Place the tube over the lit candle. You want to get the bottom end of the tube close enough to the wick to produce a stream of white smoke out of the top end of the tube. Too close to the wick, and the candle will go out, too far from the wick, and the stream of smoke will not be thick enough.  You may have to try different types of tubes and placing the tube at different angles.
Step 3: A little bit of candle science
Picture of A little bit of candle science
The white smoke coming out of the top of the tube is condensed wax vapor. A burning candle is a bit more complicated than you might think. If you think about it too much, it might drive you mad. Here is the short version....The burning wick melts the wax. The wax gets wicked up the wick. The wax vaporizes. The wax vapor (combined with oxygen and other chemicals in the surrounding air) burns. You will be splitting this vapor, so it will burn at two places.
Step 4: Lite the smoke
Picture of Lite the smoke
Once you have your stream of white condensed wax vapor, you are ready to lite it. Start with the lighter about two inches above the top of the tube. Notice how the stream of smoke does not continue above the flame of the lighter. Move the lighter lower until the flame connects to the top of the tube.
sunshiine3 years ago
Oh yeah I voted!
CHARLESCRANFORD (author)  sunshiine3 years ago
Thanks.
Kewl! I wonder if this could be considered a steam punk candle. To me it looks the part. Thanks for sharing!
Sunshiine
Probably. I am thinking of making something along the same idea, just permanent and a bit more elaborate. Once I come up with something, there will be an instructable.
Thanks for sharing! Have a beautiful fall day!
sunshiine
