Burning Decals Into Wood
8,589
75
4
Posted
Introduction: Burning Decals Into Wood
Hi, today I am going to teaching to burn decals into wood.
Here we go!
Step 1: Materials
Materials you will need are:
  • Pencil
  • Design
  • Piece of wood. ( I am using ½ Inch Plywood)
  • Router (Hand or if you have one a CNC router)
  • Torch and Lighter
  • Sander (Also if you have one a panel sander to make the finish perfect)
Step 2: Design
You need to start by having a design you want to create.
  • Choose a design that you will be able to router.(Nothing too small you can’t do)
  • Or if you have a CNC router use that but I’m guessing most won’t.
Step 3: Routering
  • Begin to router and be careful when starting some routers need a pilot hole for the router bit.
  • Router out the design.
Step 4: Burning
  • Take the torch and begin to lightly burn the surface around the design.
  • Continue to do this till the inside of the router area is nice and dark.
Step 5: Sanding
  • Begin to sand the burned area and continue to sand till burnt area is gone.
If you used plywood like me, sanding it down may have changed the colour around the design.
  • To get it all the same, you have to sand the whole board down to the same depth.
  • To make it easier of you have a panel sander, that will allow for even sanding.
Step 6: Conclusion
Hope you had fun using, Routers, Torches, and sanders.
Have a good one
  • Metal Contest 2017
    Metal Contest 2017
  • Wheels Contest 2017
    Wheels Contest 2017
  • Remote Control Contest 2017
Questions & Answers
4 Comments
how did you router that by hand?
I did not use a hand router, I used a CNC router because I had access to one. You would need a simpler design maybe if you are doing it by hand.
That looks great!
That looks great :)
