3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Burnout Lamp
Burnout Lamp
  • last photo ←
Fluorescent lamps are synonymous with the most depressing aspects of modern life: their soulless flickering presides over vast aisles of big box stores, server farms, fields of cubicles, and parking garages.  Yet, as individual objects, they are sleek, glossy white tubes, efficient in both form and purpose.  I thought it nice to marry these contradictions into a lamp that used burned-out tubes to diffuse the light from a single, working fluorescent.  The result is a study in opposites: lightness and weight, fragility and solidity, delicacy and mass.  A concrete base supports a column of white glass, classical in form and color, but modern in material and concept.
After finishing, I discovered another artist's elegant take on the burnout concept here:  http://www.castordesign.ca/
I also realized a number of shortcomings upon completion; namely, the tubes being buried permanently in concrete makes it difficult to replace a broken bulb or to move the lamp without threatening the tubes.  The next iteration, perhaps, will have sockets which facilitate swapping out the tubes for transport or repair.  In the process of making the lamp, one tube broke; I've included replacement instructions here.
Fluorescent tubes are filled with hazardous toxins, namely mercury.  Work in a well-ventilated area, and wear a mask if you break a tube.  Clean up the shards of glass with gloves.
Salvage the bulbs from your office, home, or school.  Counties and towns with bulb-recycling programs might be inclined to spare a few if you ask nicely.
You will need these materials:
eight 1-1/2" dia.burned out fluorescent tubes
8" dia. sonotube or similar
approx. 2' square of 3/4" plywood
approx. 12" of 2" dia. PVC pipe
fluorescent fixture
50 lbs. quick-set concrete mix
three-wire grounded power cord
speaker wire
toggle switch
approx 3" x 6" x 1/4" piece of plexiglass
caulk
drywall screws
You will need these tools:
Drill
Jig saw
Clamps
Box cutter
1-1/2" drill bit
2-1/4" hole saw
Needle-nose pliers
Screwdriver
Sandpaper
Dremel tool or similar
Bucket
Trowel
Step 1Formwork (1)
Formwork (1)
The formwork for the base is the most complex part of the lamp.  Start by tracing the 8" sonotube (cardboard tube concrete formwork for setting piers and posts) onto the plywood.
On two of the circles, lay out eight center points in a radial pattern.  Start by pulling one line across the circle, dividing it in two; then measure the center of that line.  Take a square and pull a line perpendicular to the first, dividing the circle into four equal pieces.  Subdivide again, just like cutting a pie, to create eight even pieces.  Measure up each line 2-1/2" from the center and make a mark.  Drill each mark with a 1-1/2" bit.  Make two identical pieces like this.  On one of them, drill out the center with the 2-1/4" hole saw bit.
Cut the two drilled-out circles out of the piece of plywood they are in.  Cut them large, so they will rest on top of the sonotube without falling in.  Cut the third small, so it will fit inside the sonotube.
Cut the PVC pipe and the sonotube to 12" long.  Sand and smooth the pipe's cut edge.
Set all these pieces aside for a minute.
46 comments
1-40 of 46next »
Nov 10, 2011. 7:48 AMgneal says:
Thanks so much for the instructions on how to build this sweet fluorescent lamp. I've been wanting something fresh and modern to go in my sitting room of my apartment. I moved into a modern looking place that has concrete formwork and it looks really slick. This lamp will compliment it nicely.
Mar 3, 2011. 9:55 AMbettbee says:
Cool 'ible!
If you spill mercury, please don't vacuum it up. Doing so can disperse it into an airborne vapor. (More than it tends to vaporize by itself.) Mercury has low vapor pressure and will vaporize at room temps. If it breaks up into thousands of little globules, the surface area increases tremendously, thus increasing the vaporization. If this happens get as much air moving as quickly as possible.
Otherwise get the environment as cold as you can as fast as you can and try to make sure the mercury does not get down into any cracks in flooring, etc. If it does, cover the areas with flowers of sulfur. You can then try to suck it up with an eyedropper, solder sucker or baster, but when you're done, do make sure to work flowers of sulfur into the crevices. And don't vacuum there.
http://www.epa.gov/hg/spills/
You can get a special foam device meant to clean mercury up by trapping the globules in its open cells. I have never experimented with other types of foam, but I would want to have one of these things around in case I were to spill any. I have always believed that these should be readily available in hardware stores, and kept in every home or office that uses neon or fluorescent tubing.
Jun 6, 2011. 9:18 PMpfred2 says:
I've broken countless fluorescent tubes but I have never seen enough mercury in any of them to actually see. There is less than a droplet in a bulb. So how you're going to see the stuff to even pick it up is beyond me.
Jun 6, 2011. 10:49 PMbettbee says:
Still you want to be careful.
To say that a tube contains "less than a droplet" of mercury is meaningless. A very small quantity of mercury can be dangerous. I was a glassblower and made neon for years, and I can tell you that there is enough mercury in neon and cold cathode tubes to be of concern.
Some people will minimize the dangers of exposure to mercury, as they will to any dangerous material, but it's up to you to protect yourself and others who may be unaware of contamination of an area with toxic materials.
Mercury exposure is not something to mess with, especially if you ever come into contact with children, or with people who may ever have children. Mercury should not be ingested in any form, in any amount. Even "less than a droplet."
Jun 7, 2011. 10:17 AMpfred2 says:
Cowards die many times before their deaths; The valiant never taste of death but once. So the moral is don't lick floors whether you break bulbs on them or not, they're icky!
Jun 7, 2011. 11:59 AMbettbee says:
Oh Lord love a duck. Mercury is not generally absorbed via licking floors. It vaporizes into the air and there is nothing you can do to avoid breathing it in at that point. If you handle it, it can get on your skin and clothing and migrate to others, or even into your washing machine or the machines at the laundromat.
If you want to risk a myriad of horrible ills, many to yourself but also including birth defects in your unborn offspring and those of others (and by now I am devoutly hoping you decide not to reproduce) then by all means ignore the dangers of this toxic yet ubiquitous substance.
Handling chemicals improperly is not valiant. It is stupid, and comes with criminal penalties if you endanger others through your idiocy and someone finds out.
Jun 7, 2011. 6:25 PMpfred2 says:
I hope you realize that less mercury is in a bulb as conventional bulbs release by generating the difference in power it takes to operate. Now who's the idiot?
Jun 7, 2011. 11:47 PMbettbee says:
That last comment didn't make sense. Conventional bulbs (I assume you mean incandescent bulbs) don't release mercury. It is true that cold cathode lamps tend to use less power, but there are other considerations aside from mercury that make them less attractive. LEDs are really the way we will have to go in future.
By the way I wasn't calling you an idiot, but rather people who deliberately or carelessly mishandle chemicals.
Anyway I've said all I can really say on the subject. I'm out . . . argue amongst yourself . . .
;-D
Jun 8, 2011. 6:43 PMpfred2 says:
I think you fail to see the big picture and have no idea where the electricity you consume comes from or what the consequences of using power are. One of which just happens to be mercury emissions. The difference in energy usage between incandescent and fluorescent lighting is large enough to more than offset the amount of mercury in the fluorescent bulbs. By several times I have heard.
BTW gallium arsenide is one of the main ingredients of LEDs sounds yummy doesn't it? The semiconductor industry has been an environmental nightmare at all phases but that is a topic for another time.
Mar 3, 2011. 2:32 PMtrmatthe says:
The mercury risks are way too overstated. I know here in the US everybody is paranoid about health risks etc, but mercury isn't the same as being plunged into a room full of hydrogen cyanide gas! Heavy metals are most dangerous to the young as they can affect brain development through denaturing of proteins, but it's not a case of "being in the same room as a broken CF bulb = instant death or terrible neurological conditions". Just keeping things in perspective. So don't worry so much.
May 14, 2011. 6:56 AMSMAKT says:
I see what you did there.
Mar 8, 2011. 10:24 AMBad Maxx says:
Bless you both for taming the overzealous mercury fear mongering. Although it certainly can cause issues people in general have an exaggerated fear of mercury.
Jun 6, 2011. 9:13 PMpfred2 says:
Yeah who hasn't had fluorescent tube Star Wars fights? Fun fun fun!
Mar 13, 2011. 8:49 AMbeehard44 says:
i think it's the placebo effect that kills
Apr 8, 2011. 8:50 PMwireless charger led flashlight says:
hehe, why try some new power for lighting?
Although this amagic technology has been found in 19th ,but to many people it is just miraculous happening. wireless power transmission can be found in mobile telephone ,electric toothbrushes, led flashlight and led bulbs.if you type "wireless power led lighting" in google,you'll find many wireless power led lighting,
TO this days ,we can find not only some mobile phones and electric toothbrushes,but also led lighting whichi's power supplied by wireless power ,yesterday I saw some power CREE led flashlight,and power led bulbs from http://www.wirelesspower-ledlighting.com/
it's really wonderful,
Mar 30, 2011. 8:48 PMgrenadier says:
Neat idea, but I would have used something like 5kVAC @ 150kHz to make the dead lamps themselves glow.
Apr 3, 2011. 7:49 PMJaycub says:
Yeah an electrostatic generator or other HV power supply will light the dead lamps. Why is this not done normaly?
Apr 4, 2011. 6:53 AMgrenadier says:
Well it costs money. You can get lamps like that; they are called electrodeless lamps and they are excited by RF energy. They cost quite a lot more, though they do last much longer.
Mar 18, 2011. 5:45 PMchicopluma says:
tou can place something like the base on the top to hide the non used conectors and it would look like a gigant light bulb
Mar 5, 2011. 11:35 AMwoutervddn says:
anyone else thinking he has found a way to use that tesla coil or vandergraaf he has lying around?
Mar 5, 2011. 10:38 AMmahesh.ganpate says:
nice .. think..
Mar 5, 2011. 7:04 AMBroom says:
Brilliant.
If you want to hide the blackened ends, spray paint them. You can create an "airbrush" graduation from fully-painted to fully-lit, without losing much of the light.
Mar 3, 2011. 6:27 PMEsmagamus says:
"Fluorescent fixtures must be grounded to work."
I have no idea where you got this from, most fixtures aren't grounded at all.
Before the grounding police comes, there are things to consider:
1) most fixtures won't be accessible from the ground, even if you touch them to replace a bulb, they're to be disconnected at that time anyway;
2) when a fixture is screwed to masonry, often the screws themselves are a good enough ground for the fixture if the fixture ever comes live.
3) grounded fixtures on damp environments often cause erratic electrical problems.
More important than grounding a ballast you'll hardly ever touch would be reinforcing the wire as it comes out of the concrete base. The sharp radius the wire can bend to will strain and break it. That is more likely to cause damage than the lack of grounding.
Mar 4, 2011. 1:58 PMGoedjn says:
Some ballasts do need to be grounded to work properly, and some don't.
On most modern ones, you can get the thing to work anyway by connecting the
neutral and ground together, but the lamp will then not start as easily, and will burn out faster. I don't know why this is so, since the ground isn't supposed to carry current.
Mar 4, 2011. 11:58 AMalzie says:
Have you ever seen the demo of flo tubes being lit by tesla coil?
You can light these with HV RF with out contacting wires.
I m thinking that you could use one of those plasma ball exciters to do this.
All six of your "dead" tubes would light up just fine,
if not as brilliantly as a connected tube.
Mar 3, 2011. 10:53 PMDoItOrDie says:
What if you placed a so-called "black light" at the center? It's just a UV light and should cause the old tubes to glow as well. This could make for an interesting effect, what with the center darker than the outside.
Mar 4, 2011. 11:54 AMalzie says:
The regular purple long wave tubes will not excite the phosphor in an adjacent tube.
The phosphor with the tube only responds to short wave UV directly from the Hg vapor.
This short wave UV will not penetrate the glass.
Mar 4, 2011. 10:28 AMkyleparisi says:
This project gave me an awesome idea... potentially my first intractable.... we shall see. This is exactly why I subscribe to the newsletter - to get ideas
Mar 3, 2011. 11:13 PMcajett2002 says:
what if you got pvc pipe that was just slightly larger than the flourescent lights and burried those in the concrete just to the top? then couldn't you just slide in the lights and then if one gets broke it's easy to slide it out and replace it? or take them out to move it?
Feb 28, 2011. 4:29 PMjj.inc says:
How does this work, if the bulb is dead what good is hooking it up to the power same type power source gonna do.
Mar 3, 2011. 8:07 AMrushourgraffic says:
How about using a high voltage RF source (inverter) and you can light up the "dead" bulbs too. (Dead just means the small heating filaments at each end used to start the bulb are burned out ) Cold cathode fluorescent bulbs don'd have these filaments and use an inverter to light them up. the larger bulbs will work the same way.
Mar 3, 2011. 7:06 PMjj.inc says:
Thats what I was wondering because I can light up my dead fluorescents with a plasma ball, which led me to believe this powered the bulbs like that, especially because the way the tops don't have light.
Feb 28, 2011. 6:54 PMjj.inc says:
k
Feb 28, 2011. 9:11 PMjustjonty says:
So good to see a use for burnt out tubes... really great idea! Thanks for including the link to castor's take too... v.helpful
Mar 3, 2011. 1:36 PMTreknology says:
I like this one better than the "castor" versons.
Feb 28, 2011. 2:14 PMbengus says:
i love it !!! what about using something to protect neon tubes ? maybe a transparent pvc pipe...or i don't know
Mar 3, 2011. 9:53 AMnerys says:
also you don't have to use an FL in the center. you can also string up LED's in the center as well. string up enough LED's and you could get the same amount of light in something that will likely outlive you :-)
1-40 of 46next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
425
Author:wholman
I am an artist, writer, and designer who graduated with a degree in architecture in 2007.
